Compression questions. - Mustang Evolution
Old 06-14-2004, 04:14 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Just a few questions about compression. Stock compression is 9.36:1. If you mill the heads .030 and bore the block .030-.040, and use flat topped pistons, what compression would you be likely to end up with?
Would the compression need higher octane gas than 89?
Would I run into problems with valve clearance?
I don't think this matters but this would be with a 4.2 crank. I'd Love some input on this. I was trying to map out my plans for the next bit of modding, I've decided to go the N/A route, and see what I kind of horsepower I can get out of it that way.
Thanks for the input guys.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-15-2004, 11:35 AM   #2
Region: Iowa
Hmm, either I've asked the wrong question, or I've stumped everybody... damn. Ok, second question. If someone could help me out, maybe I can figure it out myself. I know the bore and stroke. The only thing I don't know is the volume of the chamber in the head. The headgasket I'm going to guess is a little under an 1/8 of an inch, probably around .110 in. So does anyone have the volume or dimensions of the head? Or the volume that is lost if the heads are milled .030? As I remember the bowl isn't the same diameter as the cylinder, it's smaller. Thanks for the help, who ever can find the info, or happens to know it.
Old 06-15-2004, 11:59 AM   #3
Danger Dude's Avatar
I believe most flat top pistons run in the 10:1 or slightly higher. But the cylinder heads resurfacing and deck height has a lot to do with it. But on a stock virgin block and virgin heads with flat tops 10:1 or 10.5:1 would seem close. But like I said it all depends on what else is done to the block and heads.
RGR or Mikael at RPM could give you specifics on pistons they sell.
As far as octane requirements using flat tops might require a higher octane. I would probably say low octane 87 would be out if bumping up to 10.5 compression.
I hope this helps you out some.
Old 06-15-2004, 12:30 PM   #4
Region: Iowa
Brother Corey comes through again. Thanks man.
Old 06-15-2004, 02:25 PM   #5
Region: Iowa
If the heads are milled .030 and the pistons are changed to flat top pistons with a 4.2 crank, does anyone know if there would be valve clearance issues? Or would valve reliefs need to be cut into the piston?
Old 06-15-2004, 05:01 PM   #6
As long as you use the 4.2 rods there should not be as long as the pistons are also made to go into a 4.2 motor. Piston height varies ( measured from the center of the piston pin to the top of piston deck. As long as the measurements are the same clearance in not a great issue. There have been people that have had to shave a bit of the piston deck off to prevent the piston deck from being to tall.
Non Pi to Pi compression iwannagofast 1996-2004 Mustang GT 12 12-30-2009 10:26 PM
e6te head compression ratio questions svtlx 1979-1995 Mustang GT 10 03-20-2007 07:58 AM
what's an ideal compression ratio I_luv_HP&trq Pre-2005 V6 Mustang 15 10-16-2005 06:19 PM
Low Compression from Cylinder #2 robert0803 Pre-2005 V6 Mustang 14 04-08-2005 08:44 PM
compression Js281GT 1996-2004 Mustang GT 17 01-10-2005 05:01 PM
07:46 PM
