7.5" rear from a 96 fit a Fox Chassis that had a 8.8 - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 06-14-2004, 11:43 PM   #1
Brent is unknown around these parts
Will a 7.5" ( the one in my 96 V6) work on a fox body that originally had a 8.8 in it?
Find us on: Reddit | Facebook | Twitter
Brent is offline
Old 06-15-2004, 11:54 AM   #2
Monkey's Avatar
Monkey is unknown around these parts
yes. if it is set up for 4 lug drum brakes, you'll have to swap axles
Monkey is offline
Old 06-15-2004, 01:55 PM   #3
Zim
You want to **** me?
Zim's Avatar
Zim is unknown around these parts
is he just straigt up swapping you rear end for rear end?
I like toys
Zim is offline
Old 06-15-2004, 02:34 PM   #4
not sure yet.
Brent is offline
Old 06-15-2004, 05:44 PM   #5
Terminator Owner
SpectorV is just getting started.
you should be able to pop the cover, remove the carrier pin, remove teh c clip slide out the axles and dothe same with teh other slide in the new axles put the clips back in with the carrier then put new lube in it and be done, just wanted to make sure the axles are not to long or to short or anything odd like that.
SpectorV is offline
Closed Thread
Fox Guys - Anyone use the "Plug and Chug"? PureVenom General Mustang Discussion 13 01-24-2009 02:59 AM
Anyone looking for a fox rolling chassis? lowflyn The Bar 3 05-14-2007 04:10 PM
Fox Body '89 and 16" and 17" wheels and rims Kevin Brown Mustang Wheels & Tires 12 11-10-2005 05:56 PM
fox rear end gears? timpryor 1979-1995 Mustang GT 2 06-17-2004 08:17 PM
09:26 PM
