The stroker has begun! - Mustang Evolution
Old 06-17-2004, 11:13 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I just won an ebay auction for a 2000 f-150 4.2. I ended up paying $755, which I'm kicking my self over because if I had waited to bid on it until the last second I could have had it for $510. Still a good deal though because I'm going to drive there and pick it up and for a motor with the same miles the salvage yards around here charge $1200+ So now I'll have an extra set of heads, and 4.2 intakes to sell off to recoupe some of the cost. It'll probably take me a while to get it all put together, but I'm still really excited. I've wanted to do the 4.2 swap for several years but I'd never been able to find a resonably priced motor for donor parts.
This rules just thought I'd share.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-17-2004, 11:15 AM   #2
sweet dude good luck with it
Old 06-17-2004, 11:21 AM   #3
01mineralgrey6's Avatar
Awesome!! keep us up to date on it!:yup:
-Tony
'99 cobra 'vert
Old 06-17-2004, 05:07 PM   #4
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
:wstupid:
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 06-17-2004, 07:07 PM   #5
keep us up to date
Old 06-17-2004, 10:50 PM   #6
speedpenguin's Avatar
I know how you feel. My 4.2 internals are being balanced and i will begin building very soon.
Building of the mighty 4.2 has commenced!
http://www.mustang-forums.com/forums...ine=1085721216
http://www.cafepress.com/speedpenguin
speedpenguin is offline   Reply With Quote
Old 06-17-2004, 11:27 PM   #7
97Stallion's Avatar
Hey, since you got a 4.2 now, are you planning on swapping your engine, or swapping the internals? You may need to remove the knock sensors and plug them if you swap the whole engine. If you have any 4.2 questions, I'm your man. I think you PM'd me once before.
Living one day at a time!
Old 06-18-2004, 07:34 AM   #8
KrazyPony's Avatar
I have been seeing this 4.2L mentioned around here alot lately, what are the power gaines from the 3.8L that normally comes with the mustang v6's, any huge differance, more ummphhh when needed?
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 06-18-2004, 11:33 AM   #9
97Stallion's Avatar
The power gains are very little, but the torque gains are the real improvement here. But with the increase of displacement you allow the engine to make more power with bigger mods. For example big-valved heads on a 3.8 are kinda wasteful, but lets say you have your 3.8, and if you went to a 4.2, your engine would still in theory make the same power. But with big valved heads you could flow more useful air and then make more power. Does that make sense? When you think of your engine, think of it as an air pump. You want the air to move fast and free of disturbance. If you have an over-flow of air, the air slows down and then you result in a decrese of power.
Old 06-21-2004, 07:40 AM   #10
Region: Iowa
What I was planning to do was use the 4.2 block, get the 2001 oil pan, and then swap my heads and intakes over to the new block. I need to check and see if my ASP underdrive pulley will still work. I can't remember now if I have the one for externally balanced one or the one for internally balanced motor. Which one of those works for the 4.2? The 4.2 is internally balanced right? I was under the impression that the 4.2 block was exactly the same as the 3.8?
Old 06-21-2004, 09:47 PM   #11
97Stallion's Avatar
Yes, the 4.2 block is identical. Do you know what year the block is? if it's a 97-98 4.2L the 94-98 mustang pulleys work, and if it's a 99+ 4.2L block you can use the respective pulley and balancer or a 01+ mustang pulley.
Old 06-22-2004, 09:20 AM   #12
Region: Iowa
It's out of a 2000, same year as my mustang. They swapped the pulley setup part way through the year, to the 2001+ style, but I can't remember which one I have. I just have to look to see if I have the externally balanced pulley or not. Now, if I have the 2001+ style then it will work with the 4.2 crank out of a 2000, right?
Old 06-22-2004, 09:27 AM   #13
Zim
You want to **** me?
Zim's Avatar
think this will be done by the end of this season?
I like toys
Old 06-22-2004, 10:32 AM   #14
97Stallion's Avatar
Well if the 4.2 block is from a 2000 and you don't have it's pulley and balancer, you'll need to buy a 01+ Mustang pulley. Might as well get an underdrive pulley then. You can try your pulley, but I won't promise you anything. Just be safe and get the right one.
Old 06-22-2004, 04:09 PM   #15
Region: Iowa
Sorry, to be clear, I already have an underdrive pulley, but I'm not sure if it's the 2001+ style or not.
Old 06-22-2004, 04:10 PM   #16
the 01+ pulley has a little notch in the balancer i belive
-Tony
'99 cobra 'vert
Old 06-22-2004, 06:24 PM   #17
97Stallion's Avatar
Well if you said you have one for a 2000, then it's not the right one.
Old 06-23-2004, 06:58 AM   #18
Region: Iowa
Actually it might be. In the middle of the 2000 model year they switched it, so some 2000 actually have the same dampner as the 2001+'s. I remember being asked which kind I had when I got my ASP pulley, but I can't remember which kind I have.
Old 06-23-2004, 07:06 AM   #19
Region: Iowa
I doubt I'll have it done by the end of this season. This is going to take a while. Most of the reason it's going to take a while is because I need to save up for the parts and machine work. I'm going to have the blocked bored and get flattop pistons for it. That's going to take some cash. I haven't decided if I'm going to use forged rods yet or not. I don't plan on doing forced induction, but if I do eventually then I'll be kicking myself when I have to tear it all apart again.
Old 06-23-2004, 10:21 AM   #20
Zim
Zim's Avatar
Yeah you might as well use forged rods... even if you dont put a blower or somethin on it right away, a couple years down the road theyll still be there for ya I think its so funny how youve got all this engine work done to your car but your still runnin the stock straw exhaust and stock intake. UPGRADE THAT!! lol... that was one of my favorite gains (the exhaust / CAI ) when i added those it felt like a whole new car. :thumbs2:
I like toys
Old 06-23-2004, 11:33 AM   #21
97Stallion's Avatar
Yes that's true, but to know for sure look in your driver's side door jam and see the date of production. If it was built after 04/00 then you might get lucky. As for what Zim was saying, you HAVE to upgrade your exhaust before you do this swap. You'll be seriously choking yor motor. Do the exhaust side first when you upgrade and then the intakes.
Old 06-25-2004, 03:15 PM   #22
Region: Iowa
Well I've already got ported and gasketmatched uppers and lowers. It's true though, I'm still stock when it comes to the exaust. I'm planning to put long tubes on the new motor, and do my exhaust then, othereise I have to upgrade the exhaust twice, once for the 2.25" and then again when I put the 2.5 headers on there.
Oh, and I do have a CAI. I made it myself but it works really well. I need to look into getting rid of all that accordian crap though, between the MAF and the TB. I wonder if getting a larger TB would do any good. I've heard that doens't do much on stock vehicles but maybe with all the mods it'd help.
Old 06-25-2004, 06:55 PM   #23
97Stallion's Avatar
Yes, a 70mm on a 4.2 will help you very much, but make sure you have a good cam and heads before you get the TB though.
Old 06-26-2004, 07:38 AM   #24
slvr2000stang's Avatar
To tell which pulley style you have use the pic below to comapre to yours.
The face is completely flat on the 01+ (internally balanced)
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-26-2004, 06:18 PM   #25
i had it backwards oh well
-Tony
'99 cobra 'vert
Old 06-26-2004, 07:26 PM   #26
That's ok
2000 Vert 4R70W
Old 06-26-2004, 08:47 PM   #27
Region: Iowa
Well, no luck, mine is definatly the 99-00 style... That figures. Oh well, I'm sure I can sell it once I drop in the new block.... Or if I'm going to super charge it, I suppose I wouldn't want the underdrive pulley. I think I want to see what I can get out of my car N/A though. Hmm... I'll have to think about it. Acctually, I wonder if I can find a machine shop that could just grind off the raised part and I could use the same one.... Hmm.
Old 06-26-2004, 09:36 PM   #28
97Stallion's Avatar
It would be cheaper to just sell the one you have and get the right one without messing with it. I sure a machinist could do it for cheap, but then you'd have to worry about it being done correctly and all that, so I would just buy the right one and sell the old one for like 75 bucks.
Old 06-26-2004, 09:39 PM   #29
Ive got my stock 01 pulley still if you need it, just let me know
-Tony
'99 cobra 'vert
Old 06-27-2004, 10:00 AM   #30
Region: Iowa
I believe that I'll have the stock 4.2 pulley with the motor. Thanks for the offer though.
If the pulley is the same as the one for the 2001+ except for that jutted out part, I might just go that route. I know a master machinist that could probably do it for me.
IT HAS BEGUN! VCS_SSSTANG Pre-2005 V6 Mustang 11 08-25-2008 10:15 AM
It Has Begun!!!!! wrecked2001 1996-2004 Mustang GT 15 05-06-2006 11:14 PM
So the tear down has begun NorwegianMustang Pictures and Videos 4 05-27-2005 06:25 AM
Autocross Season has begun! Horse General Mustang Discussion 9 04-30-2004 06:44 AM
Springtime modding has begun.. stangin99 The Bar 1 02-22-2004 12:08 PM
06:34 AM
