in need of help - Mustang Evolution
Old 06-20-2004, 11:28 AM   #1
in need of help
my 02 stang has been grinding gears lately but i dont know what to do. im thinking its the clutch fluid or the clutch cable needs to be adjusted. i have a mac short shifter and i had it for a month or two without any problems but mabey it could be the shifter.
Old 06-20-2004, 08:05 PM   #2
i want to drive my car soon
Old 06-20-2004, 08:31 PM   #3
i want to be able to drive my car this week
Old 06-20-2004, 08:52 PM   #4
Tbird232ci's Avatar
check the fluid maybe?
Old 06-20-2004, 09:30 PM   #5
Danger Dude's Avatar
possible synchro's going out. Do you have alot of play in the clutch before it engages. you might be in need of a new clutch
Old 06-20-2004, 09:42 PM   #6
i only have 15,000 miles i dont think i need a new clutch so soon
Old 06-20-2004, 09:52 PM   #7
Then you might have synchro problems
Old 06-20-2004, 09:53 PM   #8
how would i check the syncro and the fluid(so u guys dont think the cable needs to be adjusted)
Old 06-20-2004, 10:00 PM   #9
do i have to take down the tranny for any of this
Old 06-20-2004, 10:06 PM   #10
Yes a Tranny place could tell you quick. The place I go to charges $ 85 to take apart and look and they deduct that cost when they fix anything.
Old 06-20-2004, 10:11 PM   #11
to put fluid in the clutch i have to take the tranny down (i can take it down myself buti would not know what to do from there) so adjusting the clutch cable probobly isnt the problem damn. i guess i will just take it too ford i still have warranty. but i have to pay 50 bucks every time i take it to get fixed.
Old 06-21-2004, 02:11 PM   #12
i just saw my clutch quadrant is bent so i am thinking thats what caused my syncros to go out i will be taking my car to the dealer so they can fix it and i will order a new clutch quadrant from steeda im sure those dont bend
Old 06-21-2004, 03:43 PM   #13
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Um.... Clutch Fluid? We don't have a hydrolic clutch. We don't have clutch fluid.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-21-2004, 03:51 PM   #14
I think he meant fluid in the tranny itself not the clutch. if the gears might be grinding because of them being dry!!!
Old 06-21-2004, 03:55 PM   #15
i thought he meant clutch fluid too
Old 06-21-2004, 05:30 PM   #16
I liek gramer
WhiteStang99's Avatar
While ur filling that clutch fluid up, you might wanna top off your headlight fluid as well
Old 06-21-2004, 05:59 PM   #17
Haha
Old 06-21-2004, 08:12 PM   #18
Zim
You want to **** me?
Zim's Avatar
yeah you dont wanna miss the blinker fluid either
I like toys
Old 06-21-2004, 10:01 PM   #19
well had my brother check out my clutch quadrant and he says it is not bent i will just take the car to the shop
Old 06-22-2004, 03:21 PM   #20
i checked my short ****er and turns out the stops got a little loose and was causing that i just adjusted the stops and now it works fine
02:57 AM
