underdrive pulley - Mustang Evolution
Old 06-25-2004, 06:34 PM   #1
Question underdrive pulley
if i put an underdrive pulley on the crank on the stang would the power sterring and alternator gett affected significantly.
Old 06-25-2004, 07:01 PM   #2
97Stallion's Avatar
Significantly, no, but you may notice your alt. doesn't fully charge your battery when you're at idle.
Living one day at a time!
Old 06-25-2004, 07:03 PM   #3
so if i leave it at idle for a while the car battery will drain
Old 06-25-2004, 11:34 PM   #4
97Stallion's Avatar
No it won't drain but you'll notice your voltage gauge won't be pointing straight up, but as soon as you give the car any gas it'll go back up to normal. So at idle you'll be getting 14.0 volts and anything else you'll be getting close to 15 volts. The way I fixed mine was I made my car idle at 900rpms via chip or flash the computer.
Old 06-26-2004, 05:26 PM   #5
how much hp and tq will i get out of this
Old 06-26-2004, 05:26 PM   #6
Seph's Avatar
Good question, I was wondering about the gains
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 06-26-2004, 05:38 PM   #7
01mineralgrey6's Avatar
im not sure exact gains, ive heard anywhere between 5-9 rwhp...i did notice a little bit when i got mine. and as for the charging i haven't noticed any problems my volt meter doesn't seem to have moved from before i got it.
-Tony
'99 cobra 'vert
Old 06-26-2004, 06:13 PM   #8
97Stallion's Avatar
Ya, your gains will be about 5hp some people will claim as much as 10hp but I don't think so. As for the gauge, I guess you can say you MIGHT see that. If you have this problem you know how to fix it now.
Old 06-26-2004, 06:14 PM   #9
i guess i got lucky on the gauge?:pnoid:
-Tony
'99 cobra 'vert
Old 06-26-2004, 06:16 PM   #10
97Stallion's Avatar
Yeah, i noticed mine gauge when I was at the track for the first time. My headlights were dimming.
Old 06-26-2004, 06:33 PM   #11
you can turn your idle screw to make the car idle more but i highly doubt you will ever have a problem with the car, I have had my pulley for a year at least and my stock oem battery from ford which sucks... i dont have any problems, but my speedcal sucks power all the time and my battery will go dead if i leave it for more than a couple days with out drivign it
Old 06-26-2004, 09:37 PM   #12
97Stallion's Avatar
I wouldn't mess with the idle screw, it's electronically controlled, that's how you want to fix that.
Old 06-27-2004, 02:20 AM   #13
it will work fine until you can get around to messing with the computer to fix it, just reads it as being more open that it normally is, but true its probably best to leave it be.
underdrive pulley blackonblack Pre-2005 V6 Mustang 17 12-29-2009 08:46 PM
Underdrive Pulley mrjones3133 Pre-2005 V6 Mustang 11 08-10-2009 03:58 PM
Underdrive pulley obxdude018 Pre-2005 V6 Mustang 7 07-27-2009 04:07 PM
underdrive pulley Risingsun 1979-1995 Mustang GT 5 07-15-2009 10:13 PM
Underdrive Pulley 3Point8 Pre-2005 V6 Mustang 16 03-25-2004 06:52 AM
01:15 PM
