nitrous and a auto - Mustang Evolution
Old 06-26-2004, 02:50 AM   #1
Send a message via AIM to cuban3jumper
nitrous and a auto
Does it matter if a nitrous system sprays while a auto is shifting? If so how do you keep a nitrous system from spraying during shifts?
1999 4r70w 3.8L V6
1/8 mile: 8.9 @ 80 mph
cuban3jumper is offline   Reply With Quote
Old 06-26-2004, 08:55 AM   #2
Zim
You want to **** me?
Zim's Avatar
It is harder on your transmission, however you can do it. If you dont want it to spray during shifts you do one of the following things: 1. Buy a window switch which you can set a "window" to which the nitrous will spray or 2. You can just turn the nitrous off manually around your shift points.
I like toys
Old 06-26-2004, 01:44 PM   #3
Thank you very much, just the info I needed.
1999 4r70w 3.8L V6
Old 06-26-2004, 03:14 PM   #4
Zim
Zim's Avatar
:thumbs2:
I like toys
Old 07-02-2004, 07:25 PM   #5
i would say just go with a push button set up for your nitrous so you can control your nitrous delivery. WOT( wide open throttle) nitrous systems are usually used with manual transmissions because your never on the full throttle when shifting.
bigpomps is offline   Reply With Quote
Old 07-02-2004, 07:53 PM   #6
on a manual you can be at full throttle when you speed shift
nitrous
What nitrous should i get upton7 1996-2004 Mustang GT 7 08-04-2009 04:42 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 01:43 PM
So tell me how Nitrous is sprayed with an auto Brent Pre-2005 V6 Mustang 26 04-24-2005 08:24 PM
Nitrous Laser02 Pre-2005 V6 Mustang 14 07-10-2004 11:13 AM
09:10 AM
