What's an S/C block worth? - Mustang Evolution
Old 06-26-2004, 08:52 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I have the chance to buy an 3.8 SC block. Just the block, for $50. Now, I'm not sure if that's a good deal or not. My question is this. Is the SC block stronger than the stock one? Could it be overbored farther than say, the 3.8 block or the block for the 4.2 that I just bought? (the 3.8 and 4.2 blocks should be the same, I know)
What about the main caps? Are those bigger than the regular 3.8 caps? Would those caps fit in a 2001+ oil pan like you need to do a 4.2 stroker?
recap questions
1. Is it worth $50?
2. Is the block thicker than a standard block so it can be bored out larger?
3. Will the main caps fit in the 2001+ oil pan a stroker would use?
4. Depending on the answers above, is it worth $50?
Thanks guys, you all rule.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-26-2004, 09:08 PM   #2
Tbird232ci's Avatar
the block is the same as the 95 or 96+ 3.8L's
as for the main's, i honestly cant remember, but i doubt youd have any benefit going with the SC mains
i wouldnt spend the 50 bucks unless you need a spare block
Old 06-26-2004, 09:47 PM   #3
97Stallion's Avatar
I heard a weird rumor about how the SC block wouldn't work with a 4.2. I'll see what I can find.
Living one day at a time!
Old 06-27-2004, 12:56 PM   #4
Tbird232ci's Avatar
i dont see why it wouldnt work, i can look into it also
Old 06-28-2004, 07:25 AM   #5
Region: Iowa
Thanks guys.
How much are YOU worth? bluemustang The Bar 60 01-30-2005 11:03 PM
Is it worth it? n8r The Bar 9 11-15-2004 07:33 PM
worth it thirstymate The Bar 3 09-02-2004 08:20 PM
Is it worth it???????? StangGt804 The Bar 15 08-14-2004 08:58 PM
what's this worth? tire The Bar 0 01-26-2004 11:20 AM
03:36 AM
