Quad Shocks - Mustang Evolution
Old 07-20-2003, 01:55 PM   #1
tire's Avatar
Send a message via AIM to tire
i was under the impression that they were bolted to the frame? i have quad shocks and an 8.8 rear and just need the brackets of which i'm trying to get ahold of myself right now. welding = money wasted :
i have wheel hop so bad if i try to burn them in 1st. 5spd and 4.10s will do that i guess!
tire is offline   Reply With Quote
Old 07-22-2003, 07:48 AM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
They are bolted to the frame, but the 7.5" rear and axles in the V6 doens't have the bracket on the axle for the bottom of the shock to connect to, so I had to have one made and welded on.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
cobra mustang quad cam engine kendall New Member Introductions & Greetings 3 06-18-2009 10:17 AM
Quad beam mod Rollin Thunder Mustang Audio & Video 0 03-19-2008 12:29 AM
AMD's First Quad Core is here.... Brent The Bar 15 11-25-2007 12:10 PM
Does anyone know of a good body shop in the quad city area? Horse Regional Mustang Discussion 3 10-23-2003 10:08 AM
quad shocks x 2 tire Pre-2005 V6 Mustang 2 07-20-2003 06:33 PM
09:38 PM
