upgrading my stang - Mustang Evolution
Old 11-30-2008, 05:18 PM   #1
upgrading my stang
hi, i have a v6 2001 i m planning to get a new set of wheels bullit style, 17 x 10.5 back, and im not sure if 17 x 8 or 17 x9 front
will the 17 x 9 can cause some rub at full sterring?
the wheels are 5.94" (151mm) back spacing and +24mm (0.94") off set
or a 17 x 8 is recommended?
carlosc is offline   Reply With Quote
Old 11-30-2008, 06:54 PM   #2
Re: upgrading my stang
The backspacing and offset is for a 99-04 wheel, so that's good. You may have some rubbing at full lock in either direction, but it's nothing serious. Just remember to allow room to turn without completely locking the wheels.
I would go with the 17x9s, they look way better than the 17x8s, they still tuck into the well too much, at least for me. Plus the wider tires are always a handling improvement.
What finish are you getting on the bullitts? black, chrome, anthracite?
Old 11-30-2008, 07:02 PM   #3
my stang is black , im not sure what look better, if chrone, o r black with chrome lip
if i put a 17 x 9 set on front the backspacing is 5.94" (151mm) and offset +24mm (0.94") ?
Old 11-30-2008, 07:24 PM   #4
OOh! Black with black /chrome wheels is hotter than hell! Look up some pics on american muscle to see how it looks. Chrome looks really good also.
If you do get black ones, i would get it with the chrome lip, it looks way better than the solid black.
and yes, the specs on 17x9s is 5.94" and +24.
17x8s is 5.72 backspacing and 30mm offset
Old 11-30-2008, 07:28 PM   #5
The 9 inch wheel will not be a problem. Been running a 9 inch wheel with a 275 width tire on mustangs for a few years now. Rubbed a little in the V6 at full lock...fix to that was not to go full lock.
Old 11-30-2008, 07:43 PM   #6
si black with chrome lip or chrome?
i like both
Old 12-01-2008, 08:26 AM   #7
that rim with that offset WILL rub at full turn but you dont need to turn it that much~ its not a bad rub either, it will rub a little on the front sway bar and the inner fender. The 03 cobra had a lock limiter to keep them from rubbing on it FYI.
Old 12-01-2008, 12:03 PM   #8
1234's Avatar
So if you put the lock limiter on a different Mustang would it work?
Upgrading LCD Thomas91169 The Bar 6 12-29-2007 01:32 AM
Upgrading on a budget nbennett Pre-2005 V6 Mustang 4 05-13-2007 06:54 PM
Upgrading vBulletin... again... Brent ME Site Help & Announcements 6 01-18-2005 08:37 PM
Upgrading vBulletin.... again Brent ME Site Help & Announcements 12 01-07-2005 09:55 PM
Upgrading my v-6 elijah Pre-2005 V6 Mustang 41 10-10-2004 08:56 AM
06:11 PM
