swaybar question - Mustang Evolution
Old 07-01-2004, 11:37 AM   #1
Zim
You want to **** me?
Zim's Avatar
swaybar question
when i changed my springs on the front i had to unbolt the front swaybar to allow my A-arm to fall enough, and when i tightened it back up, i noticed it didnt really get "tight" cause of the bushings on there. Is that a sort of adjustable sway bar up front? How tight should I tighten that down and what difference will it make if its looser or tighter?
I like toys
Old 07-01-2004, 11:41 AM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
With the springs dropping it about an inch, the sway bar won't be in the stock position. You can get shorter endlinks to correct that but you don't NEED them. At least, I think this is what you are talking about.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-01-2004, 11:47 AM   #3
Zim
Zim's Avatar
im talkin about the 2 bushings thats the sway bar sits on that is in the front wheel wells. They dont just tighten up to a specific point, they could be loose, or i could mash the bushings and itd be really tight... get what im sayin sorta? When i do my front struts ill take a picture of what im talkin about to clarify it a bit more.
I like toys
swaybar carlosc Pre-2005 V6 Mustang 11 12-25-2008 10:08 PM
rear swaybar advanatges? tedness Pre-2005 V6 Mustang 21 10-21-2005 11:59 PM
Front 99 GT swaybar Danger Dude Mustang Parts for Sale and Wanted 0 05-25-2005 10:09 AM
99+ GT Rear Swaybar Shahrum Mustang Parts for Sale and Wanted 3 03-17-2004 03:55 PM
Swaybar hardware Adawg Pre-2005 V6 Mustang 10 11-17-2003 11:43 PM
10:30 AM
