recommended repair/maintenance books - Mustang Evolution
Old 07-24-2003, 05:16 PM   #1
Send a message via AIM to Squirrel
Does anyone have a link to the sites were you can buy them?
Danny - In need of a mustang.
Squirrel is offline   Reply With Quote
Old 07-25-2003, 07:44 AM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Has anyone installed the FSM Smokedya is talking about on a WinXP or Win2000 machine? I have a suspicion that they won't install on those operating systems. It could be just mine though.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-25-2003, 10:24 AM   #3
Why? If it says it needs another OS to run just right click on the file and go to Compatiblity and check a OS that it will work with.
Old 07-25-2003, 01:05 PM   #4
Region: Iowa
It just gives me an error that says "there was a problem in the setup file" or some crap like that and won't install. I followed that guy's directions but still, no luck. that's why I was wondering if anyone else had that same problem.
Old 07-25-2003, 04:23 PM   #5
Rick0636's Avatar
I have that on my windows 2000 machine, no problems.
Old 07-28-2003, 07:32 AM   #6
Region: Iowa
Hmm, I'll have to try redownloading it then.
Thanks Guys.
Old 07-28-2003, 10:15 AM   #7
Rick0636's Avatar
I got this one from some guy on 3.8 on disk.
Old 07-29-2003, 09:51 PM   #8
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
You have to follow the directions exactly , and burn it to a CD it wont work installing off of your hard drive.
I installed it and it works fine after you fully follow the directions on that site
Rellik is offline   Reply With Quote
Old 07-29-2003, 10:13 PM   #9
Rick0636's Avatar
I use the CD, bought it off that guy on 3.8, think I paid him like 5 or 10 bucks for it.
Old 07-29-2003, 11:37 PM   #10
Yea, there are settings in the files where it has to be copied on CD.
just as long as they follow the directions listed on that site it will work.
Old 08-02-2003, 08:04 AM   #11
Did u ever get it?
Maintenance?? Ken The Bar 9 10-04-2009 08:53 AM
Tranny Maintenance LSUstang Pre-2005 V6 Mustang 0 06-26-2008 11:15 AM
Books n8r The Bar 17 01-17-2007 09:48 AM
General Maintenance lowflyn Pre-2005 V6 Mustang 69 01-11-2005 07:15 PM
Maintenance lowflyn Pre-2005 V6 Mustang 7 11-10-2004 06:28 PM
04:31 AM
