Driving Curves - Mustang Evolution
Old 07-04-2004, 09:20 PM   #1
ttpancakes's Avatar
Send a message via AIM to ttpancakes
Driving Curves
I am trying to learn how to "heel toe" although the correct way to do it with for toe on the brake and heel on the gas is a little bit to hard. It seems that i need to have a longer foot or different placement. I have also tried to do it the opposite way, although I get the same results. Does anyone else have a different method or, can you tell me how you guys do it, and how you learned? Thanks a lot or advice or any help.
ttpancakes is offline   Reply With Quote
Old 07-05-2004, 08:47 AM   #2
Did you raise your accelerator pedal yet?
Laser02 is offline   Reply With Quote
Old 07-05-2004, 01:39 PM   #3
ttpancakes's Avatar
how exactly do you do that
Old 07-05-2004, 01:46 PM   #4
http://www.mustangworld.com/ourpics/fcar/99pedals.htm
Old 07-05-2004, 04:57 PM   #5
ttpancakes's Avatar
Thanks although when i go to a hardware strore is that exactly what its called a "nylon spacer" or do you have a better pic of what it looks like.
Old 07-05-2004, 05:20 PM   #6
I have never seen a "nylon spacer" at any hardware store. What I did was take a little metal tube and make a slit in it and slip it over the cable and put a hose clamp around that to make sure the cable doesn't somehow come out. I read someone on another board did it with the sleeve of a pen, but I figured that wouldn't last very long.
Old 07-05-2004, 05:28 PM   #7
ttpancakes's Avatar
hmm sounds like a good plan. Seems like it would be hard to make the slit in to fit over the cable?
Old 07-05-2004, 05:57 PM   #8
Dremel and a vise.
Maybe a hacksaw and a vise.
Old 07-05-2004, 08:11 PM   #9
ttpancakes's Avatar
either way i will find a way to get it done.
Old 07-05-2004, 08:58 PM   #10
There's no like... "right"... way to do it. Just look under there and you will see the cable coming through the back of the accelerator pedal. You just need something to pull that cable out an inch or so. My way works, but it was kind of a PITA, so if you find a better way, let us know.
Old 07-08-2004, 12:37 AM   #11
ttpancakes's Avatar
I did what you said and so far it works great. Although it is hard to get the hang of it at first, it is pretty fun to barly press the accelerator and it take off.
Old 03-25-2005, 05:31 PM   #12
fastmustangs1's Avatar
Thumbs up
Yes you must modify the gas pedal. Raise it so it is even with the brake
pedal. Heal and Toe does take practice, but the end result is harder
through the turns.
Matt
fastmustangs1 is offline   Reply With Quote
Old 03-25-2005, 05:37 PM   #13
dont waste your time taking up the slack in the petal it will just stretch back out as mine did... now i cant remove the spacers or the car wotn go WOT
Old 03-28-2005, 06:03 PM   #14
ttpancakes's Avatar
And you tell me this 8 months later..thanks
Old 03-28-2005, 06:10 PM   #15
Old 03-29-2005, 11:19 AM   #16
I've been heel toe braking since i got my liscence . i'm 20 now and i must admit at first it was hard but when you keep trying it gets easy like driving stick, it becomes second nature. I 've never heard of puting your heel on the gas and your toe on the brake cause then your bending yoru leg in and the human body doesn't do well with pigeon toe, when your toe faces in. its a lot easier to have your heel on the brake and your toe on the gas. i haven't modified my gas pedal at all so it is a little lower than my brake pedal but it doesn't effect my heel toe braking. just keep practicing, you'll get it.
bigpomps is offline   Reply With Quote
Old 03-29-2005, 12:25 PM   #17
what exactly is the advantage to heel/toe driving other than having faster access to the brake
Old 03-29-2005, 03:13 PM   #18
heel toe braking alows your rpms to remain high so when you down shift your syncros in your tranny are at the right rpm to easily shift to the next lower gear. it puts less strain on your tranny and its syncros and you can keep more speed through corners by keeping your rpms up and your foot on the gas and brake.
Amazing Driving... at7311 General Car Discussion 7 12-04-2008 10:21 PM
So As I was driving last night..... ridenmystang Pictures and Videos 19 01-26-2008 10:28 PM
Driving School: MarkuzLS1 The Bar 13 03-11-2006 08:26 PM
Got pulled over, not driving tedness The Bar 21 08-03-2005 10:37 PM
2 years from now what will you be driving? sonic04edge The Bar 46 03-19-2005 11:03 PM
04:46 AM
