detroit locker vs. limited slip - Mustang Evolution
Old 07-05-2004, 07:29 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
well i would like to find a good detroit locker for an 8.8 but i have found a bunch of diffrent brands and all of them are "the best". but main question is other then the fact that you can flip a switch and lock the limited slip. is a locker any better then a fsm t-lok? thanks for your help
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 07-05-2004, 07:32 PM   #2
97Stallion's Avatar
Are you talking about a line lock? If so, thats whats use to help do burn-outs at the track. It locks you front wheels so you don't go flying down the track and you can get your slicks nice and sticky.
Living one day at a time!
Old 07-05-2004, 07:38 PM   #3
no i was told a detroit locker (like the one by auburn) is a limited slip but you can lock it up by a switch in your car so there is no time when there is power not sent to the driver side wheel. like i was always told there is a sec or 2 b4 power is sent to your other wheel.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 07-05-2004, 08:10 PM   #4
Monkey's Avatar
don't buy the locker. (most lockers are a PITA to switch anyway). The only time you would want your posi locked is at the 1/4 track, and that is it. If you go around a corner, and the wheels are locked up, then one cannot turn faster than the other, and you will wear your tires fast and get the screaching sound. as for a FMS posi taking 1-2sec, divide that number by about 1000. It takes generally a few milliseconds for a differential to react to slippage.
I had an auburn posi in my 8.8 when i had my mustang, and loved it. the FMS one is good and will hold enough power until you need a stronger one due to a huge blower and whatnot, but by then, you'll need to change to 33spline axles anyway.
Old 07-05-2004, 09:10 PM   #5
Monkey is so damned smart.
Laser02 is offline   Reply With Quote
Old 07-05-2004, 09:43 PM   #6
yeah ive noticed that too
Old 07-06-2004, 07:35 AM   #7
wow thanks monkey. you summed it all up an now i kno to stick with a t-lok. thanks for the help. o and how my rwhp do u think i need to put down b4 i need a set of 33 spine axles? im looking at about 260-280 rwhp with this roots blower
Delta Sigma Phi
www.DeltaArmsCo.com
Old 07-06-2004, 02:13 PM   #8
97Stallion's Avatar
You'll be fine with your 28-spline rear. And i think he means 31-spline.
Old 07-06-2004, 06:39 PM   #9
Monkey's Avatar
yeah, sorry, you will need over 300 at the wheels easily before you need 31 spline.
Old 07-06-2004, 06:48 PM   #10
cool thanks guys.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 07-08-2004, 05:35 PM   #11
a detroit locker is either on or off it clicks in or its off to slip it makes alot of noise and its NOT for cornering ONLY for drag use.... its a bad idea you dont need it anyway.... an auburn diff is all you will ever need and doubt you will ever get above the nees for a 8.8's tlok
Old 07-08-2004, 06:34 PM   #12
slvr2000stang's Avatar
You can always throw an extra clutch in a t-lok to tighten it up.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-08-2004, 08:19 PM   #13
Monkey's Avatar
heck, if you really really really want to, you can weld the spider gears together in the diff and that will turn your t-lock into a true locker
Old 07-09-2004, 08:02 PM   #14
tell me
I need to know if the new eaton electronic locker is any good. I already toasted the regular eaton locker. I actually drag race at the track, and need to know if it's worth the money. I drive to the track ,race all nite, then drive home ,so a spool is out of the question. I run mid 12's, with a c-4, on drag radials....
BIG T is offline   Reply With Quote
Old 07-10-2004, 10:24 AM   #15
Monkey's Avatar
just get an auburn traction lock differential. you are wearing out your locker because you are driving your locker on your daily driver. You are taking corners with a locker and your tires are locking up and putting stress on the diff and tires.
get a limited slip posi unit and you will be able to last longer on that
Old 07-10-2004, 01:27 PM   #16
your kidding
i intend to win. i'll never win bracket racing with a litemed slip. my 60 foot times change 2 tenths with the eaton working.
Limited Slip Rainman64 Classic Mustangs 2 10-17-2009 12:24 AM
limited slip manic5_2001 2005-2010 Mustang GT 10 04-11-2008 12:01 AM
Posi, T-Lock, Limited slip? fasternu_674 Pre-2005 V6 Mustang 2 10-16-2007 11:23 PM
Limited Slip Differentials SuperItalian Pre-2005 V6 Mustang 6 06-12-2007 03:48 PM
06:31 PM
