Getting my PCM out - Mustang Evolution
Old 07-06-2004, 01:20 PM   #1
Getting my PCM out
Ok I cant figure it out. There is this bolt that is holding a white bracket on the pcm and none of my sockets are fitting it. Its a gold bolt. I took the bolts holding in all the wires out. But what is the size of that last bolt!!! a 6mm is to big and a 5mm is to small!!!
Old 07-06-2004, 01:36 PM   #2
Got it!
Old 07-06-2004, 02:11 PM   #3
I liek gramer
WhiteStang99's Avatar
so what size was it?
Old 07-06-2004, 02:14 PM   #4
dont you have 5.5mm socket they are very useful
Old 07-06-2004, 11:59 PM   #5
7/32" for a bracket bolt and the harness is 10mm.
Alberto@American MotorSport
www.americanmotorsport.com
Supercharged '00 4.2L Mustang, 5-sp
-Vortech (custom setup using 94-98 kit), 12.5psi, IMRC's, custom power pipe, 80mm Lightning MAF, 42# injectors, FMS 8.8 rear-end, 300lph returnless pump, polished '99 Cobra's, Tri-ax shifter, 160° thermostat, FMS Aluminum Driveshaft, high-flow H
313rwhp/311rwtq
americanmotorsport.com is offline   Reply With Quote
Old 07-07-2004, 09:10 AM   #6
Yea I couldnt find a 7/32" anywhere so I was trying everything else. But I finally found one
« gasket | f2 chip »
Question regarding PCM flashing 05bluestang 2005-2010 Mustang GT 8 01-27-2008 09:23 AM
98' V6, 3.8 AUTO PCM PART#??? alexx_302 Pre-2005 V6 Mustang 0 01-23-2006 03:27 PM
PCM question...car's not starting! Oxygenetic Pre-2005 V6 Mustang 2 12-12-2005 05:30 PM
03:15 PM
