Rear end gears - Mustang Evolution
Old 07-06-2004, 10:29 PM   #1
ttpancakes's Avatar
Send a message via AIM to ttpancakes
Rear end gears
On a stock v6 04' what is my inches for a rear gear?
http://www.stangsuspension.com/store/comersus_listCategoriesAndProducts.asp?idCategory=65
And also there are 2 types of differentials? would mine be the one for v6?
Thanks
ttpancakes is offline   Reply With Quote
Old 07-06-2004, 10:33 PM   #2
timpryor's Avatar
Thanks
they're 7.5 but if you can upgrade to an 8.8 if you do 7.5 you should get a t-lock too if you upgrade to a 8.8 you just need gears.
btw is your car stick or auto?
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 07-06-2004, 10:38 PM   #3
If your not going to drag race your car stick with the 7.5 and just get a t lok and gears.
Otherwise I would upgrade
Old 07-07-2004, 12:17 PM   #4
ttpancakes's Avatar
to upgrade to an 8.8 would i need to buy anything extra or just the other size?
And its a manual
Old 07-07-2004, 12:36 PM   #5
i think it depends on if your car has abs
Old 07-07-2004, 01:54 PM   #6
For a 8.8 Swap you are swaping your entire rear end out. brbr let me get a picture of my 7.5 in my garage.
Old 07-07-2004, 02:04 PM   #7
This is what you swap out in a 7.5 -> 8.8 swap.
Old 07-07-2004, 02:32 PM   #8
ttpancakes's Avatar
hmm...so the gears are what is inside of that in the middle right? And if i get the ford racing 7.5 gears will the be better than the stocks? And also, how expensive would it be to totally swich out for an 8.8?
Where does the differential go?
Old 07-07-2004, 02:35 PM   #9
http://www.mustang-forums.com/forums...achmentid=1689
That is the picture inside (Thats a 8.8 only difference is a Traction Lok and bigger parts)
Anything is better than stock. Get some ford racing 3.73 Gears and Traction Lok
Swapping out rears varries. Depends on where you get the 8.8 and if you want to install it yourself or have someone else do it
Old 07-07-2004, 02:55 PM   #10
the 7.5 and 8.8 are identical minus the rear middle round part is bigger and the gears inside are bigger and the tlok is bigger... thats it its just stronger, even the axles are the same the only issue you need to worry about is get a rear end from the same year as your car or swap over your axles to fix the length, pre 93, 94-98, 99 up are all different axle lengths. the swap is very easy and in the end its really only 150 more~ to buy a brand new 8.8 with gears and tlok already installed adn ready to bolt in.... i would buy a new 8.8 or a used one that you know is in good condition.
Old 07-07-2004, 03:18 PM   #11
ttpancakes's Avatar
the traction lock is to make both wheels spin right? also what is the difference between the gears and the differential?
Old 07-07-2004, 04:40 PM   #12
the differential is the whole unit the gears go inside the diff
Old 07-07-2004, 06:06 PM   #13
ttpancakes's Avatar
haha then why do they sell the differential and the gears if you can just buy the gears?
Old 07-07-2004, 06:12 PM   #14
When You Ahve The Gears And The T-lok And The Pumpkin That Whole Unit Is Called The Differential Or As Many Others Call It The Third Member
Old 07-07-2004, 09:06 PM   #15
I liek gramer
WhiteStang99's Avatar
Why Did You Capitalize Every Word In Your Post?
Old 07-07-2004, 10:26 PM   #16
shift button was stuck
Old 07-07-2004, 10:42 PM   #17
lol i dont know why but i alwasy think someone is yelling when they talk in all caps i even read it to my self like that ha ha
Old 12-04-2007, 03:02 PM   #18
Re: Rear end gears
I was told that if i switched to 3.73 gears in my v6 that I wouldn't only lose alot of gas mileage, but it would mess up my spedometer/RPM's as well. I plan on draging my car on the weekends, but it is also my only source of transportation. is it still worth it to make the swap?
corkwood06 is offline   Reply With Quote
Old 12-04-2007, 07:26 PM   #19
Re: Rear end gears
You will lose about 2mpg on the highway and gain about 1mpg in the city~ there about. I averaged 21mpg in my 01 v6 with bolt ons and no tune and 3.73 gears. You will shave off 2.5 tenths or so in the quarter going to 3.73 gears. Your speedo will be off but with a 100 buck speed cal (if you have a manual tranny) you can fix it. You can also fix it with a programmer so just get a custom dyno tune and fix it if you go that route. It is expensive but the best thing you can really do~
Rear End gears 2007STANG Pre-2005 V6 Mustang 19 03-23-2009 06:38 PM
rear end gears o3mustangGTafs 1996-2004 Mustang GT 2 07-17-2006 08:42 PM
rear end gears?? chipshot101 1996-2004 Mustang GT 1 07-22-2004 08:05 PM
stock 99+ V6 rear end gears cuban3jumper Mustang Parts for Sale and Wanted 3 03-27-2004 04:20 PM
Rear End gears? RedDragonV6 Pre-2005 V6 Mustang 3 03-18-2004 03:12 PM
03:49 PM
