Thermostat - Mustang Evolution
Old 07-07-2004, 07:42 PM   #1
Thermostat
I bought a new thermostat. The guys at Kragen sold me a gasket. The gasket doesn't look like the thermostat housing on my car. Therefore, I believe I was sold this gasket in err.
Can anyone confirm this for me? I'd rather not tear up my current gasket to realize I have the wrong gasket on the bench.
Here is a picture of the gasket they sold me:
My thermostat does not have the little "O" thing in the upper left. Not sure what that is for! But I don't have one.
Laser02 is offline   Reply With Quote
Old 07-07-2004, 08:09 PM   #2
Just use gasket maker (silicone) and don't worry with the gasket. It will be fine.
Extreme Effects.com is offline   Reply With Quote
Old 07-07-2004, 08:13 PM   #3
I sure am a dumbass.
Old 07-07-2004, 09:51 PM   #4
97Stallion's Avatar
Yes, that is definately NOT the right gasket. You can go with silicone if you want or go get the right gasket. You already paid for it.
Living one day at a time!
Old 07-07-2004, 09:54 PM   #5
So the next obvious question is... Did they even sell me the right thermostat? Though, I don't think a picture will help with determining that one.
Old 07-07-2004, 10:04 PM   #6
97Stallion's Avatar
well what kind of thermo is it? Stant? I think your best bet is to just go back and verify the thermo and switch out the gasket for the right one. I had something like this happen to me before. I needed an alternator, so I went to the store, and bought it. I just looked it really quick, it looked like the right one. Took it apart and polished the hell out of it. Turns out it was the wrong alt. I was so mad. So I took it back and got the right one. No questions asked.
Old 07-07-2004, 10:09 PM   #7
It's a prestone 300-180. It cross-references to Stant's 13008 and 13308.
Edit: According to a quick search, Stant's 13008 is the correct thermostat. So. I'll be doing that tomorrow.
Old 07-07-2004, 10:21 PM   #8
97Stallion's Avatar
I go this info from the stant website:
Thermostats:
- Premium Thermo, Part #45359
- Economy Thermo, Part #13009
Thermo Gasket:
- Thermostat Gasket, Part #25138
I'm going to assume you have a 2002 right?
Old 07-07-2004, 10:23 PM   #9
97Stallion's Avatar
What kind of search did you do?
Old 07-07-2004, 10:26 PM   #10
I searched on V6Power and they said it was the right one.
Are those 195* thermos or 180*? I believe this one is a 180* off a 95 5.0 but it is the same one for 3.8s.
Old 07-07-2004, 10:35 PM   #11
97Stallion's Avatar
Well I just did a search on the stant website, and it gives me the same part numbers for 5.0's and 3.8's. You can tell if it's a 195 or a 180. it should be stamped on the front on the thermo.
Old 07-07-2004, 10:39 PM   #12
180/82 is stamped on the front. I'm fairly confident now it's the correct one... Unless Kragen's database and v6p are both wrong. Unlikely, I think.
It's almost not worth driving down there to pick up a new gasket, considering I'll spend twice as much in gas.
Old 07-07-2004, 10:41 PM   #13
Maybe that's a 5.0 gasket...
Old 07-07-2004, 10:44 PM   #14
just get high temp silicone
Old 07-08-2004, 02:08 AM   #15
97Stallion's Avatar
Yeah, i think it is the right thermo. Even the other one thermo that stant list is off by one number.
Thermostat stuck open ?? duals 1996-2004 Mustang GT 2 09-08-2008 12:08 AM
Need help replacing thermostat floridamba Pre-2005 V6 Mustang 1 04-01-2007 06:30 PM
thermostat? ryanxup Pre-2005 V6 Mustang 3 11-27-2006 08:17 AM
Thermostat 97conv6 Pre-2005 V6 Mustang 18 06-13-2005 06:41 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 11:00 AM
04:01 PM
