differences betwen 4.2 and 3.8 crank Pulley? - Mustang Evolution
Old 07-09-2004, 08:15 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
2 questions. Is the crank pulley from a 2000 4.2 the same as the 01+ internally balanced pulley for the 3.8?
If you have an internally balanced 3.8, can you swap the 4.2 pulley on for it are they interchangable?
Thanks guys.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-09-2004, 04:13 PM   #2
97Stallion's Avatar
yes, they are completely interchangable.
Living one day at a time!
Old 07-09-2004, 04:35 PM   #3
mid 00 up was neutral balanced in the 3.8 so its interchangable in those years.
Old 07-14-2004, 09:24 AM   #4
Region: Iowa
Sweet, that's what I thought. Thanks a lot guys.
March underdrive crank pulley Torchred02 1996-2004 Mustang GT 4 01-23-2007 02:09 PM
cant get crank pulley off Thomas91169 1996-2004 Mustang GT 23 03-23-2006 09:25 PM
94-98 Underdrive Crank Pulley dapack69 Mustang Parts for Sale and Wanted 0 09-29-2005 10:09 PM
removing crank pulley... MonteCitan 1979-1995 Mustang GT 15 03-01-2005 10:48 PM
Crank Pulley and New Harmonic Dampner Stang01 Pre-2005 V6 Mustang 1 07-17-2003 06:36 PM
08:24 AM
