mufflers - Mustang Evolution
Old 07-10-2004, 11:55 AM   #1
jimmy_beaner's Avatar
Region: Iowa
mufflers
first, I'm building a custom side exhaust thing. Is there any room in front of the area of the rear axles for mufflers? I don't really wanna go back to go forward, to go out the side. Also, which would sound best: Dynomax or Magnaflow? Sponsers, if you wanna make me an offer, I'd be happy to take a look. I really want to run dual mufflers. Could I maybe run it along side the driveshaft, not CLOSE to it, but near it, but just turn it? Or is that a big no no? And yes, I'm cutting my side skirts... and I'm constructing rectangular exhaust tube after the mufflers. It will give me more ground clearance than round tube, and I am maintaining equivalent volume of tubing. I understand this means the tube must be about 3''-4'' wide. I have a 4' by 4' sheet, I'll have plenty.
Old 07-10-2004, 01:39 PM   #2
you can buy side exit mufflers that have the inlet and the exit on the same side of the muffler, pretty easy to get some, then you just run the flow tube from the H or what ever (if its a v6 you need to buy a pacesetter dual exhaust adapter and some flow tubes to bolt up to it then weld the other end of the flow tubes to the inlet on the muffler, then bend you some pipe out of the muffler over to the side skirts, but the stock side skirts probably are not low enough and the stock frame will get in the way .... but im sure you have taken care to look at what you are dealing with adn taken off the side skirt to see what kind of clerance you are gonna have to work around. check with some of the site sponsors at the bottom of the forum page they can direct you to products that you need/dont want to fab up, you can buy a pre made fully side exhaust kit from spintech i know.
Old 07-10-2004, 01:46 PM   #3
Region: Iowa
side exhaust=$1000.... MY JOB....$200
Old 07-10-2004, 02:58 PM   #4
spintech is NOT 1000 for the kit more like 300~
Old 07-10-2004, 04:25 PM   #5
get side exhaust 300 bucks aint that bad
Old 07-19-2004, 10:05 AM   #6
Region: Iowa
no longer doing the side exhaust anyway, here come straight pipes I guess, still have the Magnapacks
No Mufflers ?? DaDant! 1996-2004 Mustang GT 26 03-10-2009 11:17 AM
Mufflers 5-2-Floor 1979-1995 Mustang GT 41 09-12-2007 07:56 AM
Mufflers 00BlackStang Pre-2005 V6 Mustang 20 03-07-2007 07:54 PM
GT Mufflers vs. V6 Mufflers? downtime Pre-2005 V6 Mustang 20 04-08-2006 04:27 AM
Mufflers Black00GT Mustang Parts for Sale and Wanted 1 01-28-2004 09:18 PM
04:08 AM
