calipers - Mustang Evolution
Old 07-12-2004, 11:38 PM   #1
calipers
http://www.gefracing.com/Merchant2/m...y_Code=BULLITT
how many pistons do these have
Old 07-13-2004, 01:18 AM   #2
Two.
Laser02 is offline   Reply With Quote
Old 07-13-2004, 09:48 AM   #3
are these much better than stock with 13 inch rotors
Old 07-13-2004, 10:03 AM   #4
They are at least twice as good.
Old 07-13-2004, 10:12 AM   #5
same as on my 01 bullitt....
they are great, you will not be disapointed, and they will work wonders with some sorta aftermarket rotor....
ford rotors suck!
daniel is offline   Reply With Quote
Old 07-13-2004, 10:18 AM   #6
Danger Dude's Avatar
Actually Ford rotors dont suck bad. The problem is they wear fast with the use of High performance pads. The real culprit in pre 99 single disc calipers is they are not up to performance driving. They fade fast. when i am screaming down the closed runway near me I have to coast a ways to loose some speed before I start pumping the brakes or they will heat up really fast and fade out bad.
Old 07-13-2004, 10:21 AM   #7
if i do get those i would get them with some 13 inch power slot rotors
Old 07-13-2004, 10:27 AM   #8
you would need 13 in rotors period with any Cobra or Bullitt calipers
Actually the gains in stopping for general drivving will be small but you actually gain weight do to the larger steel Rotors. Unless you are doing Autocross most V6 cars dont require big *** brake calipers and rotors.
I am not saying dont do it just there are better mods that actually give you better performance gain for the money.
But I think Cobra / Bullitt calipers look bad ***
Old 07-13-2004, 10:37 AM   #9
all that matters is looks
naw im just playing i will be getting black bullet rims pretty soon so i thought i should upgrade my front brakes while im at it
Old 07-13-2004, 10:45 AM   #10
http://www.gefracing.com/Merchant2/m...egory_Code=38L
are these better
Old 07-13-2004, 10:49 AM   #11
or these
Old 07-13-2004, 10:54 AM   #12
They are the same manufacture PBR they will be the same one is grey the other is Red
either choice is good !!!!
Old 07-13-2004, 10:55 AM   #13
but are those better than the bullit calipers
Old 07-13-2004, 11:04 AM   #14
No they are the same. Why would they be better ????
Old 07-13-2004, 11:26 AM   #15
Rick0636's Avatar
The Cobra Calipers are actually a little less money than the red bullitt ones and I hear easier to get, but like Corey said, the same other than the color basically. I wanted Power Slot front rotors, but I cheaped out and got the ones that came in a kit for a lot less, cross drilled , slotted and not treated for rust, they are ok.
Old 07-13-2004, 12:34 PM   #16
so which should i get
Old 07-13-2004, 12:46 PM   #17
Why ask us what you want???? They are the same one is red, one is grey
What color do you want!!! That is the question
Are you a libra ??? They cant make their minds up for nothing
Old 07-13-2004, 12:47 PM   #18
Rick0636's Avatar
Whichever you like the best! I would check to see if they are backordering the Bullitt ones though, they were putting them on long term backorder not long ago.
Old 07-13-2004, 12:55 PM   #19
i will get the cobra now what i would like to know is if i have to buy these rotors (cross roadz direct)
Powerslot 1994-2003 Cobra Slotted Brake Rotors FRONT (Pair)Price: $239.00
NOTE: Fits 1994-2003 Cobra Mustangs
Venting the gas from super heated brake pads improves overall brake performance. Of the various venting methods, slotting has the clear advantage. Slotting, unlike drilling, is not prone to cracking. Plus drilling delivers considerably less active braking surface - 8% less than Power Slot Rotors. The tapered slot also channels brake dust and heat away from the rotor and pad for improved braking ability. Power Slot Rotors are CNC-machined and come with an anti-corrosion plating that looks great behind custom wheels.
  • FEATURES:
  • CNC Machined
  • Anti-Corrosion Plating
  • Slots Keep Rotor Cooler
  • Slots Keep Rotor Cleaner
  • Improved Wet Braking
This includes both front-left and front-right slotted rotors. Please add the two rear rotors seperately if you want them as well.
Old 07-13-2004, 12:59 PM   #20
also what else would i need to buy i.e. hoses or bolts
Old 07-13-2004, 12:59 PM   #21
Do not get the aft because the Cobra rear rotors are to big for your stock rear calipers. You can get any Front rotors you want for your car as long as they are for Cobra's. There are many manufactures
Old 07-13-2004, 01:01 PM   #22
i wasnt gonna get cobra rotors for the back i was just gonna get some slotted rotors for the back that were the stock size. but for the front those rotors will fit right.
Old 07-13-2004, 01:05 PM   #23
yes but you should go look at Ebay there are some very competitive prices. I bought some Hawk slotted rotors for 70 with shipping
Old 07-13-2004, 01:09 PM   #24
so what else will i need to install these any new hoses or banjo bolts anything or do these use every thing that i already have
Old 07-13-2004, 01:09 PM   #25
i will look on ebay for the rear ones thnx
Old 07-13-2004, 01:15 PM   #26
I would get new SS lines with new Banjo bolts
Why dont you save money and buy a complete kit with Calipers, Rotors and new brakelines
Old 07-13-2004, 01:20 PM   #27
how much would that be i dont want drilled rotors btw
i will be buying the rotors and calipers at the same time
Old 07-13-2004, 01:24 PM   #28
these say they already come with pads are those good or would i need to buy other pads
Old 07-13-2004, 01:32 PM   #29
Those pads will do just fine
Old 07-13-2004, 01:34 PM   #30
thnx corey and rick :thumbs2:
now respond to my other threadunder this one in suspension and drivetrain
Old 07-13-2004, 03:47 PM   #31
the caipers are not much better than the 99 ups its mainly in the extra rotor size... but its a definatly nice up grade my cars stops 30% better than it used to~
Old 07-13-2004, 04:02 PM   #32
how much did you get yours for and from where are they drilled or slotted
Old 07-13-2004, 09:55 PM   #33
97Stallion's Avatar
The stock calipers on the 99+ mustangs are pretty good for almost anything you really need. Is us fortunate one with 94-98 mustangs that need the upgrade done. So I upgraded mine to the 99+ style and the braking is much smoother and quicker. I forgot who even started this thread, but my recommendation is that 94-98 mustangs upgrade to the 99+ PBR dual calipers and get some powerslot rotors and leave it at that. And if you're going for a more custom look, paint them and add you own mustang like I did.
Living one day at a time!
Old 07-13-2004, 09:59 PM   #34
97Stallion's Avatar
here's what i was talking about simple yet original. It's an old pic, so don't be a hater.
Old 07-13-2004, 10:21 PM   #35
i started the thread and i have an 02 so i guess i wont do this mod if its useless
Brake Calipers Topxshelfxtre Pre-2005 V6 Mustang 8 04-11-2010 09:49 PM
Painted calipers jmp782 Pre-2005 V6 Mustang 11 07-12-2008 11:25 PM
painted calipers?? Drewskie Mustang Audio & Video 9 08-22-2007 10:11 PM
Difference between 99 GT and 99 V6 Calipers? Brent Pre-2005 V6 Mustang 11 06-12-2005 10:11 PM
2003 V6 Calipers? Cope Pre-2005 V6 Mustang 8 02-01-2005 09:24 PM
11:27 AM
