Increasing Top Speed - Mustang Evolution
Old 07-13-2004, 05:13 PM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
I know my car will cut off at 115 cuz of the chip, but if I get a chip how fast will it run. Can it run more than 120mph? How do I get it to run 140+? How would CAI, exhaust, and pulleys affect top speed? What parts should I add to run 160mph?
megax29 is offline   Reply With Quote
Old 07-13-2004, 05:17 PM   #2
Dom
Dom's Avatar
Send a message via AIM to Dom
Gearing is how you go faster.
After the speedo goes past 110-ish, it's really not accurate.
Old 07-13-2004, 05:19 PM   #3
megax29's Avatar
What the hell does gearing mean? Changing gears to 8.8in or upshifting manually.
Old 07-13-2004, 05:25 PM   #4
when you change gears you change gear ratio changing to an 8.8 is to have a stronger diff it doesnot affect your car at all unless it has a higher gear ratio installed well the t-lok would be the difference if you get an 8.8
Old 07-13-2004, 05:26 PM   #5
wait i dont think what i said makes sense but read it over and over and maybey youll get it
Old 07-13-2004, 05:30 PM   #6
sarges_heroes20's Avatar
a saleen s-281 wing is a arodynamic mod. u might think about getting one of those. lowering your car will allow less air under your car so that helps on the arodynamics aswell.
if u get a front spliter for your bumper u will get less air under and more being forced around the car.
top speed is all about two things, gears & arodynamics. thats it. next time a auto cross race is on tv look at how the cars are set up. there low, got tall ricer like wings, and front bumpers to the ground and side skirts just as low. rear bumpers are small, reason is if they keep the air out from under neath the car they can create a low pressure area, allmost a vacum (cars can't get the seal all around to get a true vacum) that keeps the car on the ground as its driving around the track at 200+ mph.
Hope i helped shed some light on the subject.
To HELL with our enemies,
GOD Bless America! :patriot:
sarges_heroes20 is offline   Reply With Quote
Old 07-13-2004, 05:32 PM   #7
I liek gramer
WhiteStang99's Avatar
BUT do not think that making your car look fast will make it go fast.
You need more mods than a chip to go that fast.
Also, try to keep threads of a similar topic in one place
Old 07-13-2004, 05:34 PM   #8
a cai exhaust and pullies arent gonna make you go 160 you need lots of work to go 160
Old 07-13-2004, 05:35 PM   #9
megax29's Avatar
Ok but what changes exact changes do I make to my car to go faster? The power in the engine is what I'm really concerned. If I add the bumpers and lower it and change the gears I won't go faster than 115mph cuz of the chip. Need speed!
Old 07-13-2004, 05:37 PM   #10
megax29's Avatar
I don't want it to LOOK fast I want it to be fast. You say I need lots of mods to go that fast, what are they? Like in phases or where I should start. I want to get the Ram Air shaker system as my CAI so start with that.
Old 07-13-2004, 05:39 PM   #11
who?? me or them?? im talking about goin faster.
Old 07-13-2004, 05:40 PM   #12
if you put the chip and raise your limiters you can go as fast as the engine goes but the v6 engine cant really go that fast unless you have some reall power adders like sc or tubros, or if you go na cams, heads,ported upper and lower intakes and much more. so in conclusion if you want to go that fast be prepared to spend alot. also why would you ever want to hit 160 thats a great way to kill yourself even at the track
Old 07-13-2004, 05:40 PM   #13
http://www.mustang-forums.com/forums...ead.php?t=5654
Old 07-13-2004, 05:41 PM   #14
you better finish all the way to stage 4
Old 07-13-2004, 05:42 PM   #15
I liek gramer
just a general statement
Old 07-13-2004, 05:42 PM   #16
on stangs u do need the chip that removes the govenor on the spedometer. with out that u will never get the use out of other top speed mods.
Old 07-13-2004, 05:44 PM   #17
Old 07-13-2004, 05:46 PM   #18
Ok to throw all this information in one topic and keep it organized:
A chip will do this:
It will improve your shift points, take off your speed and rev limiter. This means that you are no longer limtied by speed.
The chip will also remove check engine codes for eaxample if you have removed your catylitic Convertors.
Your engine stock will not go 160 mph.
To get even close to that you need to get Ported Heads, intakes and one hell of a cam. A 4.2L Stroker doesnt hurt either
Old 07-13-2004, 05:50 PM   #19
megax29's Avatar
So if I am to add a chip, Ram Air system, wiring, pulleys, exhaust, and shift kit how fast will I go? Anything else I consider hardcore when you change cams and heads and **** like that on the engine. Those additions are my primary upgrade in near future but may wanna go 160mph. What should I expect with these upgrades and is 160mph out of reach?
Old 07-13-2004, 05:53 PM   #20
ITS IN REACH BUT NOT WITH chip, Ram Air system, wiring, pulleys, exhaust, and shift kit
Old 07-13-2004, 05:56 PM   #21
You wont be close to 160 with those. You dont need to go anywhere near that speed anyways. You get caught doing that and your spending the night in jail
Old 07-13-2004, 05:58 PM   #22
and they will probobly take your car away if you do 160 and suspend your license
Old 07-13-2004, 06:00 PM   #23
anyway those are the mods you need to do.
Heads/Cam/Intakes before you can even see thnk of that kind of speed
Old 07-13-2004, 06:00 PM   #24
Zim
You want to **** me?
Zim's Avatar
throw a .25:1 ratio rear differential gear in there and youll see 200+
I like toys
Old 07-13-2004, 06:00 PM   #25
megax29's Avatar
Is this a place to discuss ways to modify V-6 Mustangs or a counseling place?
Old 07-13-2004, 06:02 PM   #26
Old 07-13-2004, 06:03 PM   #27
megax29's Avatar
So more about the heads/cams/intake. What heads, cams and intake should I get to go that fast.
Old 07-13-2004, 06:05 PM   #28
port and polish you heads and intakes and get a custom ground camshaft for you application also all those other smaller mods like cai and exhaust and chip and gears will help you
Old 07-13-2004, 06:13 PM   #29
megax29's Avatar
So how much am I looking at to "port and polish you heads and intakes and get a custom ground camshaft for you application also all those other smaller mods like cai and exhaust and chip and gears will help you" and will I go 160mph then?
Old 07-13-2004, 06:17 PM   #30
cai 50 bucks off ebay
exhaust $300
chip $300 i think
gears and t-lok $800 including instalation
camshaft and heads and intakes i dont know
going 160mph priceless
Old 07-13-2004, 06:22 PM   #31
Zim
Zim's Avatar
im gonna go out on a limb and say youre not gonna get your car close to 160mph
I like toys
Old 07-13-2004, 06:28 PM   #32
megax29's Avatar
some may say a sturdy limb. but whitestang said cai and intakes, they're not the same thing. CAI = Ram Air right? You have either CAI or Ram Air right? and intake isn't the same as Cold Air Intake?
Old 07-13-2004, 07:00 PM   #33
If you want the best be prepared to dish out anywhere between 3 and 4k dollars for a well built 4.2L engine.
Old 07-13-2004, 07:09 PM   #34
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
cai is cold air intake it is where the car sucks in outside air for the engine, intake is an acctually part of the engine, ram air is somethin outside of the car to bring air in possibly to a cold air intake or your stock air box
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 07-13-2004, 07:11 PM   #35
uh they all bring air in from the outside.
A CAI pulls air from the fenderwell area.
A Ram air kit is put so that when you drive the air is literally being rammed inside the intake tube. This air is usally colder. This doesnt help unless your going fast enough.
top end speed v6stang04 Pre-2005 V6 Mustang 60 03-02-2010 12:36 PM
Top Speed torched07 Pre-2005 V6 Mustang 49 08-09-2007 01:47 AM
V-6 Pony package top speed st1100boy Pre-2005 V6 Mustang 48 05-01-2006 11:50 PM
Top Speed with 4.10, Tlok, & F2 Fordchip Donny B Pre-2005 V6 Mustang 5 11-27-2003 10:17 PM
lose top speed lowflyn Pre-2005 V6 Mustang 2 09-17-2003 03:30 PM
04:34 AM
