another 3.8-4.2 question. - Mustang Evolution
Old 07-14-2004, 09:38 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Is the TB on a 2000 4.2 the same as the 3.8 one?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-14-2004, 10:47 AM   #2
tire's Avatar
Send a message via AIM to tire
what's the bigger Q?
(sorry i do not know the answer to this question though)
austin
tire is offline   Reply With Quote
Old 07-14-2004, 11:50 AM   #3
97Stallion's Avatar
which 3.8 are you comparing this too? Single port or SPI?
Living one day at a time!
Old 07-14-2004, 12:03 PM   #4
i'm guess he is comparing 2000 3.8 to 2000 4.2
Old 07-14-2004, 01:23 PM   #5
Region: Iowa
Yeah, sorry, I guess that was a bit unclear.
Old 07-15-2004, 08:52 PM   #6
Monkey's Avatar
the 99+ had 60mm throttle bodies and that is enough flow for an N/A v6. Since you have to put the stock upper manifold back on, just keep w/ the stock TB.
Old 07-16-2004, 08:16 AM   #7
Region: Iowa
Not why I'm asking. What I want to know if if the 4.2 TB is the same size as the 3.8 one I figured I could half shaft it, and sell it to someone with a mustang.
Old 07-16-2004, 08:56 AM   #8
97Stallion's Avatar
Do you have a 4.2 TB in your possesion? If you do, measure it and multiple it by 25.4 and that will give you the mm. So if you get about 2 3/8" then it's a 60mm TB, if you get just over 2 1/2 inches then it's a 65mm TB
Old 07-16-2004, 02:29 PM   #9
Region: Iowa
Sweet, thanks. Not to sound retarded, but what does the stock 2000 mustang come with? 60? 50?
Old 07-16-2004, 09:37 PM   #10
01mineralgrey6's Avatar
60mm
-Tony
'99 cobra 'vert
thanks for the help one more question JAYS MUSTANG Pre-2005 V6 Mustang 3 09-16-2006 10:07 AM
Sub Question graystangguy06 Mustang Audio & Video 9 06-26-2005 12:56 PM
Question 98VroomVroom Mustang Wheels & Tires 4 03-29-2004 06:25 PM
Question 98VroomVroom Mustang Audio & Video 1 03-28-2004 01:29 PM
Question 98VroomVroom Mustang Wheels & Tires 1 03-27-2004 10:20 AM
04:58 PM
