v6 clutch pedal - Mustang Evolution
Old 12-11-2008, 12:11 PM   #1
v6 clutch pedal
I have a 2001 v6 w/ a 5 speed .I have noticed recently that the clutch pedal rattles at different speeds. I have tried the owners manual adjustment suggestion but the problem remains. Any suggestions??
Bill D. is offline   Reply With Quote
Old 12-11-2008, 12:59 PM   #2
Re: v6 clutch pedal
Define rattle, you hear it, feel it, etc?
If its a squeel that is only at given rpms (or speed) that goes away when you push the clutch in then its the throwout bearing not the clutch petal.
Old 12-11-2008, 06:32 PM   #3
Re: v6 clutch pedal
No squeel I can feel it in the pedal and hear it when I begin to slow down
Old 12-31-2008, 12:05 PM   #4
Re: v6 clutch pedal
Old 12-31-2008, 12:05 PM   #5
Re: v6 clutch pedal
Any other sugestions?
Old 12-31-2008, 01:35 PM   #6
Re: v6 clutch pedal
if the petal feels notchy not really a vibration as much as its not smoothly sliding in/out thats about what I went through. I kept having throwout bearings go out. It may just be the throwout bearing, but if you go through the hassle of changing that you need to change the bearing retainer sleeve (what the throwout slides on) check the input shaft play, pressure plate and clutch with a new or resurfaced flywheel... i know thats everyuthing lol oh and the clutch cable as well and make sure the fork arm is not sliding on the dust shield and making it stick a bit (first thing to check as its one bolt lol just follow where the clutch cable goes into the transmission, take off that little cover the fork arm is where the cable attaches, look for rub marks in the little dust sheild from the fork arm)
thats about all i have. I never fixed mine, I just kept the squeel away due to keeping tension on the clutch cable.
My clutch pedal is pissing me off!! 5ohPony 1979-1995 Mustang GT 4 09-11-2007 12:40 PM
car moves with clutch pedal to the foor jedwards242000 Pre-2005 V6 Mustang 4 03-12-2006 12:05 AM
pedal covers mustangruss Mustang Audio & Video 16 10-27-2005 09:07 PM
Look its fast64's clutch pedal assembly steedav6builder The Bar 14 04-09-2005 10:35 PM
clutch pedal sags? tedness Pre-2005 V6 Mustang 4 03-19-2005 11:10 AM
12:44 PM
