Secondary Air Injection blah blah blah - Mustang Evolution
Old 07-14-2004, 04:17 PM   #1
BruThru2002's Avatar
Send a message via AIM to BruThru2002
My check engine light came on today, so i went ahead and scanned the computer. Said the secondary air system circuit shows low voltage. So Im guessing a sensor that has to deal with the air injection system these cars have on them has gone bad. Im not sure what sensor they are talking about thought. Anyone know the name of it??? Thanks.
2000 Mustang....
~ Performance Red, New Mach 1 (Mag 500) rims, Dual Flowmaster Exhaust, Black Letters & Rocker stripes, Sony - Rockford Fosgate system
-Billy
BruThru2002 is offline   Reply With Quote
Old 07-14-2004, 05:18 PM   #2
the only sensors i can think of is the IAC, idle bypass valve, and maf sensor. buy some electronic no residue contact cleaner and clean the maf wires up good if you have a pre 01 you will see a little sensor behind the maf on the air inlet tube pop it out and clean it to (its the iac) and the idle bypass valve is located behind the Throttle body its around cylinder shaped, bolted to the upper intakes back side.
Old 07-14-2004, 09:58 PM   #3
BlueDonkey's Avatar
I had this pop up; the smog pump went bad. Replaced the pump and the code went away. The secondary Air Injection takes outside air and puts it into the exhaust manifold. Helps with emissions.
BlueDonkey is offline   Reply With Quote
Old 07-14-2004, 10:18 PM   #4
That seems an awful lot like cheating.
Laser02 is offline   Reply With Quote
blah..... Brent The Bar 16 08-12-2005 01:29 AM
blah Zim Pre-2005 V6 Mustang 4 03-01-2005 04:34 PM
blah Brent The Bar 11 01-12-2005 03:44 AM
Blah...shift knob. Dom Mustang Audio & Video 3 02-26-2004 11:49 AM
01:05 AM
