Where to buy 8.8 or racing 7.5 - Mustang Evolution
Old 07-14-2004, 04:36 PM   #1
ttpancakes's Avatar
Send a message via AIM to ttpancakes
I want to change my gear set up but I cant find any places that sell the whole back end which i will need to upgrade to an 8.8 gears. Also would a 7.5 from ford racing benfit me enough? What would be the best way to go?
ttpancakes is offline   Reply With Quote
Old 07-14-2004, 04:50 PM   #2
tire's Avatar
Send a message via AIM to tire
for 90% of people that don't race much and don't want to use sticky tires, gears and a tlok in your stock 7.5 will be fine. depending on the deal, the 8.8 will cost you about the same or 100+ more but you can run slicks at the drag.
austin
tire is offline   Reply With Quote
Old 07-14-2004, 04:58 PM   #3
steedav6builder's Avatar
Send a message via AIM to steedav6builder
texas mustang has them but they are kinda pricey http://www.texasmustang.com/
i didnt find em on their online catalog but they are in their paper one if u have them send u one
steedav6builder is offline   Reply With Quote
Old 07-14-2004, 05:14 PM   #4
ttpancakes's Avatar
so having the ford racing 7.5 gears are better than what comes stock with my car now? and if so would i be able to tell the difference?
Old 07-14-2004, 05:16 PM   #5
if you plan for your car to ever see any track time go ahead and get an 8.8 its not much more if any depending on install costs.... www.gefracing.com has 8.8s you can get around 800 bucks last time i checked you can get a used 8.8 pretty cheap also if you look around, but its alwasy better to buy new so you know what you are getting.
Old 07-14-2004, 05:34 PM   #6
ttpancakes's Avatar
If i got the 4.10 instead of the 3.73 with the stock 7.5, would that help at all?
Old 07-14-2004, 05:44 PM   #7
no its not the gears is the weak spider gears that break usually as long as you dong go to the track it will be fine, unless you get a POS install and the gears whine and break.
Old 07-14-2004, 05:51 PM   #8
ttpancakes's Avatar
so the only thing that will help me out is getting a bigger differential like an 8.8? The gears dont matter then? I am confused. All in all what would help me out if i dont want to upgrade to the 8.8? What would i need if I wanted to get the 8.8?
thanks
Old 07-14-2004, 06:02 PM   #9
the gears matter alot i dont think you get it an 8.8 is the size of the differential and 4.10 and 3.73 are the gear ratios, by the looks of it you dont need an 8.8 you already have a 7.5 diff incase you didnt know that , so all you have to do is get some 4.10's im assuming your car is auto if its manual get 3.73's and get a t-lok you dont need an 8.8
Old 07-14-2004, 06:06 PM   #10
ttpancakes's Avatar
Thank you very much. Also is a t-lok, a separate peace or what. Is all the gears and sizes a limited slip or is that something different. Sorry for all the questions but I thought i new what i was talking about till today.
Old 07-14-2004, 06:11 PM   #11
a t-lok will replace your open diff which only allows one whell to spin with a t-lok (limited slip) both your whells spin
now gears will get you better acceleration like i said if you have an auto get 4.10 if you have a manual get 3.73's
Old 07-14-2004, 06:40 PM   #12
you don't need an 8.8 without some major **** done to your car, like nitro turbo or supercharger. 7.5 is plenty capable of lasting through anything a bolt on V6 could throw at it.
jugador is offline   Reply With Quote
Old 07-15-2004, 01:45 AM   #13
ttpancakes's Avatar
thanks a lot for you guy's help.
Old 07-15-2004, 01:46 AM   #14
ttpancakes's Avatar
Dont GT's come with 3.73 stock?
Old 07-15-2004, 01:49 AM   #15
3.27
Old 07-15-2004, 01:59 AM   #16
It's going to cost $170 for gears and $200+ for the install. You might as well get a complete 8.8 rear for $300 and change and actually make it right and reliable.
Laser02 is offline   Reply With Quote
Old 07-15-2004, 07:31 AM   #17
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
the 7.5 and 8.8 are 2 different animals. the 7.5 is stock on mustang v6's, and the 8.8 is stock on gt's. the 7.5 is smaller and weaker, not really up to the stress of racing. recommended for daily driving and an *occasional* trip to the track... the 8.8 is the beast.. bigger, stronger and better built. it's able to take a lot more wear and tear before it goes out on you. if you're running over 250rwhp and plan on running even more, then you might as well switch to an 8.8 now, it'll save you the cost of a swap later on...
if you have a manual tranny, then you'll want 3.73 gears, no matter which differential you get. if you have an automatic, then you'd be better off with 4.10's. it has to do with shifting and rotation, or so i'm told
but yes, if you plan on racing a lot, or building your engine up over 300-ish hp, then i'd say just jump up to the 8.8. better safe than sorry
also, a good mod to do at the same time would be to get an aluminum driveshaft put on, they run around 130$... it'd save labor charges to get both mods done at the same time
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 07-15-2004, 11:12 AM   #18
i broke a spider gear in half with a stock 7.5 and my car having only bolt ons... its not about the power its about the shock on the rear end you launch hard enough they will break....
Old 07-15-2004, 11:15 AM   #19
how much is an 8.8 cost new and one used
Old 07-15-2004, 02:29 PM   #20
used go for 300-400~ and new 800-900
Old 07-16-2004, 12:38 AM   #21
ttpancakes's Avatar
I dont really plan on having a race car, I just want it to be fast and be able to go driving with my friends. My friend is my mechanic and very knowledgeable about cars. Getting the 3.73 gears with my 7.5 should be fine because i dont plan on again "Making a race Car". Just need the little more acceleration for the feel of it, along with the t-lok. Well thats what i think. But if anyone can see or get me a used 8.8 let me know please because it is worth it, but I dont want to spend that $ and not use it.
Old 07-16-2004, 10:17 AM   #22
as long as you never go to a real race track and run your car the 7.5 will be fine if the stuff is installed right, but.... its only 200 more~ for an 8.8 in the end.... do it right and get and 8.8 or you will be sorry down the line. I know I am you never know what you will be doing with the car later on.
Old 07-16-2004, 10:32 AM   #23
i want an 8.8 is it ok to get one used or should i get a new one. if i get one used would i be able to just rebuild the t-lok and get new gears on the 8.8
Old 07-17-2004, 02:29 AM   #24
ttpancakes's Avatar
anywhere else i could buy one?
Old 07-17-2004, 07:31 AM   #25
you could probably buy a used 8.8 for pretty cheap and put some gears adn rebuild the tlok (if it needs it) for cheap 500-600 with gear install and all~ but look for one with the gears already in it.
Old 07-17-2004, 10:25 PM   #26
i just might consider an 8.8 used it comes out the same as just getting gears and a t-lok for the 7.5 and icould install it myself so screw my 7.5
Old 07-18-2004, 04:16 PM   #27
IF you find a 8.8 that you KNOW is good, trust the person, or you can ride in the car and see how it rides, no gear noise test it up to 65-75mph for gear noise coast all the way down to listen for gear whine. you should be ok then but i would pop off the cover and inspect the tlok clutches and gear wear along with all the bolts to make sur ethey are tight.
should i buy lookin41 New Member Introductions & Greetings 8 01-28-2010 04:16 PM
looking to buy a 5.0 need some help mustang0386 1979-1995 Mustang GT 7 12-08-2008 08:25 AM
Should I buy it? Zim The Bar 25 06-18-2006 01:43 PM
some neat ideas about life and racing (mostly racing) RGR Pre-2005 V6 Mustang 2 02-09-2005 02:14 PM
Alittle ricer drag racing/street racing show on History channel video Brent The Bar 15 05-06-2004 11:26 PM
07:48 PM
