4.10 gears - Mustang Evolution
Old 07-18-2004, 01:48 PM   #1
jimmy_beaner's Avatar
Region: Iowa
4.10 gears
I was wondering how much worse gas mileage I'll get with 4.10 gears. I have a 2001 Mustang, v-6, and right now, I get an honest 27.5 when I'm driving like a good boy. When I'm not, it falls off to I don't know what, but what kind of gas mileage could I expect with the 4.10 gears? Is it worth the loss of gas just for the increase in acceleration?... are 4.10 gears better than 3.73?
Old 07-18-2004, 03:44 PM   #2
i hear its not that big of a drop so go for it you get way bettere accel
Old 07-18-2004, 04:13 PM   #3
well with my 01 v6 manual with all my mods listed and 3.73 gears i manage 22mph if i drive good/city highway mix make sure you are checking it right by filling up and going till empty then filling up and divide the miles you went by how much gas you put back in.
you should see 2-3mpg drop on the highway and 1-2 gain in the city.
Old 07-18-2004, 04:21 PM   #4
i see your not going the 4.2 liter route how much hp will you be making with all those mods and also tq
Old 07-18-2004, 04:22 PM   #5
who me? or the thread starter? with all in that list also adding in long tubes and an off road or highflow H 2.5 pipe MAYBE probably 2.25 i will be 240-255 rwhp and 240-255rwtq peak power at 5800~ and with a 2.0-1.9 60ft and good shifting should see 13.5-13.8s
Old 07-18-2004, 04:26 PM   #6
Zim
You want to **** me?
Zim's Avatar
my milage didnt drop at all in the city, and on the highway i lost about 2-3 mpg
I like toys
Old 07-18-2004, 04:36 PM   #7
yes i was asking you spector
Old 07-18-2004, 07:31 PM   #8
Region: Iowa
how much faster is your car? Also, which is better 4.10 or 3.73? How much should I put back for install?.... is it worth it to get the shift kit at the same time?... will I have to worry about breaking some other part of my car?
Old 07-18-2004, 08:52 PM   #9
3.73 are worth 2.5 tenths on a 99 up and 4.10s about another tenth off your times. i would not upgrade the 7.5 only buy an 8.8 but if you do the install should be 200-400 bucks depending on how bad you gear your butt hole raped
Old 07-19-2004, 03:56 PM   #10
if you do alot of highway driving at high speeds with 4.10s, you're gonna blow your engine, well not blow it but decrease it's life drastically. i have 3.73s and i'm doing around 4,000 rpms at 98mph. with 4.10s it's gonna be higher.
i'll give you a specific number tommorow.
but yes, acceleration is much, much better.
All pigs are useless!
widowvirgin is offline   Reply With Quote
Old 07-19-2004, 06:03 PM   #11
you wont mess up anything.... your rpms will be 400 more~ with 4.10s in a 99 up, do you see 99 ups not lasting as long as pre 99s? the pre 99s have 2.73 vs 99 ups 3.27 thats a diff of .50~ vs 3.27 up to 3.73 for a diff of 50~ and 4.10s are only 200 rpms higher.... by the time it will matter you wont care or the motor will run out of life from other reasons
Old 07-19-2004, 06:35 PM   #12
if you say so, just don't say i didn't warn you. 3.27s to 4.10s make a world of difference.
Old 07-19-2004, 07:02 PM   #13
Zim
Zim's Avatar
i went from 2.73's to 4.10s... it rules
I like toys
Old 07-22-2004, 02:02 AM   #14
tire's Avatar
Send a message via AIM to tire
moving to v6 tech...
my 00 v6 5spd had 4.10's... they were about right for the car. 4.30's for auto should be good.
gas mileage highway went from 28 to 23 or so. a friend of mine got 24-25 with another 00 v6 5spd and 4.10's. i strongly recommend at least 4.10's if not 4.30's. 3.73's on an auto is weaksauce. and yes, a shift kit will make a big difference.
don't fear the gear.
austin
tire is offline   Reply With Quote
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
» Members Mustangs
Lucy
Rawly
Redstang
rclason
Add your Mustang
11:07 PM
