Help! Serious problem. - Mustang Evolution
Old 07-19-2004, 08:24 AM   #1
I was driving on the I-10 yesterday and my car topped out at 110. I think I need NOS. Two of the big ones.
...No. Seriously. What would prevent my car from going any higher than 110? Clogged fuel injectors? Pump? It wasn't stuttering out anything... It just would not go any faster. The RPMs wouldn't go up (I think it was around 3500 in OD.) Anybody have any ideas?
Laser02 is offline   Reply With Quote
Old 07-19-2004, 10:47 AM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Your computer is limited to 110-115. Get an aftermarket chip and you'd be able to go a bit faster. I've had mine up to 120 since I got my chip.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-19-2004, 10:56 AM   #3
Zim
You want to **** me?
Zim's Avatar
its called your rev/speed limiter dood Only way to remove that is a chip.
I like toys
Old 07-19-2004, 11:12 AM   #4
No no. Maybe I wasn't clear enough about what I'm talking about... When I hit my speed limiter (118) my engine cuts in and out and my car shakes and I can feel it. This time it just sat at 110 and wouldn't move any higher. It was definitely not hitting the limiter yet.
Also: In second gear as soon as I hit 4500 rpms my rpms drop to 3900 and I have to climb back up to 4500. Is this normal? Is it related? Etc.
It's just acting funny all the way around.
Old 07-19-2004, 11:17 AM   #5
Zim
Zim's Avatar
you have gears?
I like toys
Old 07-19-2004, 11:22 AM   #6
97Stallion's Avatar
Do you have an auto, or a 5-speed? And in 2nd gear, do es it only send you back down to 3900rpms once or everytime? Does it do it in any other gear?
Living one day at a time!
Old 07-19-2004, 11:26 AM   #7
sounds like something to do with spark plugs.. or something along those lines
Old 07-19-2004, 11:41 AM   #8
Danger Dude's Avatar
Get a tune up. It could also bad gasoline, Bad plug wire, need to clean your MAF(if you have a K&N filter, change or clean your filter, A really hot day with low moisture, Head wind, fat *** in the passenger seat, clogged fuel filter.
Your problem can be a number of things or combined things. Start with a tune up
Old 07-19-2004, 11:51 AM   #9
tire's Avatar
Send a message via AIM to tire
weird. i'd start with a tune-up as stated above.
tire is offline   Reply With Quote
Old 07-19-2004, 12:52 PM   #10
97Stallion's Avatar
I was thinking the same thing. Kinda like a spark plug/wire problem. Try that route first.
97 A/C problem phaw16 1996-2004 Mustang GT 7 07-20-2009 12:39 PM
a/c problem 02MustangV6 Pre-2005 V6 Mustang 0 12-26-2006 02:44 PM
Problem.. lowflyn Pre-2005 V6 Mustang 15 07-25-2005 12:52 PM
03:47 AM
