Reburned Chips - Mustang Evolution
Old 07-19-2004, 11:10 PM   #1
ttpancakes's Avatar
Send a message via AIM to ttpancakes
Reburned Chips
Just wondering, If I was the only one that thought a reburn was not worth it. You can get a chip and then add mods because it doesnt matter that much. No matter what whatever mods that you put in after your chip, your car is still going to run better. Your computers will get used to your mods and change to them, and you dont have to keep reburning.
ttpancakes is offline   Reply With Quote
Old 07-19-2004, 11:21 PM   #2
timpryor's Avatar
unless you get a S/C or gears that will change ALOT and you need to get a reburn although yes it will run better after a mod has been installed a mod helps the engine take full advantage of your mods.
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 07-20-2004, 12:10 AM   #3
you need a chip for alot of things
You get it reburned for head cam swaps, Superchargers, gear swaps etc etc
Old 07-20-2004, 12:11 AM   #4
timpryor's Avatar
i was simply stating a few things of the more common items
and the things would run better with would be more bolt on related items
Old 07-20-2004, 12:13 AM   #5
if you have a chip burned for a stock car say you did a rear end swap like me with 4.10s and then I went out and bolted on a cold air intake, underdrive pulley and exhaust I would not need a reburn for that.
Major mods that alter air/fuel ratio do
Old 07-20-2004, 12:33 AM   #6
timpryor's Avatar
true you wouldnt NEED it but from what I've READ it would help take advantage of those other mods
Old 07-20-2004, 01:55 PM   #7
those little bolt ons get you too little power its not worth getting a reburn for that an seeing another horses
SLR CHIPS 01 PR RAGTOP 1996-2004 Mustang GT 3 08-25-2008 12:48 PM
cheap chips 98mustang2007 Pre-2005 V6 Mustang 3 12-22-2007 06:20 AM
Chips? RioStang Pre-2005 V6 Mustang 11 04-24-2006 06:13 PM
Chips Chips Chips skylar1926 Pre-2005 V6 Mustang 10 10-08-2004 08:15 AM
Ebay Chips 97conv6 Pre-2005 V6 Mustang 6 09-26-2004 10:26 PM
03:48 PM
