Are all Cold Air Intakes The same? - Mustang Evolution
Old 07-20-2004, 08:53 AM   #1
I have been looking through Ebay and there are many different CAI for my 2003 V6. I was wondering if there are any real differences between them or can I just buy the best priced one?
Any advice would be appreciated.
bel
belmor2 is offline   Reply With Quote
Old 07-20-2004, 09:36 AM   #2
slvr2000stang's Avatar
The basic design is pretty much all the same.
The only minor difference I have seen is the distance between the 90* bend into the fender and where the MAF is mounted. The longer the distance there the smoother the airflow into the MAF which gives it a more accurate reading.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-20-2004, 09:50 AM   #3
97Stallion's Avatar
For the most part yes they are the same, but there are two different kinds. Fenderwell and non-fenderwell. The non-fenderwell basically just removes all the dust covers from the filter in your engine bay and this hurt performance by actually sucking the hot air from your engine bay, so it's basically an oxy-moron. It should really be called a Hot-air induction kit. And a fenderwell kit takes air from inside your fenderwell. This benefits you by sucking in more dense, cooler air. And we all know when air is more dense there are more ppm in a given area, and therefore when it heats back up and explodes you have more oxygen in your cylinder to help fuel your fires and your result is more horsepower.
Living one day at a time!
Old 07-20-2004, 01:49 PM   #4
Send a message via AIM to kaper232 Send a message via Yahoo to kaper232
Read this article, there is a lot of good information in it...
http://v6stangs.com/index.php?page=v.../cai/index.php
kaper232 is offline   Reply With Quote
cold air intake
Looking for a cold air intake maxwelmurder Pre-2005 V6 Mustang 10 08-31-2008 08:41 AM
Cheap cold air intakes? mitch Pre-2005 V6 Mustang 15 03-23-2007 11:14 AM
Mass Air Flow and Cold Air Intake Mike's-stang Pre-2005 V6 Mustang 1 08-20-2004 09:24 AM
11:39 AM
