need to know the hub assembly part# - Mustang Evolution
Old 07-20-2004, 09:32 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I need a hub assembly (pass. side) for my 2000 V6 to fix a bad wheelbearing. The problem is all the parts houses only have a listing fo the ABS equiped hub assembly. If anyone knows of a good part lookup website, or can just find out what the part# is, please let me know so I can have the parts house do a cross look up and I can get a part cheaper.
Thanks
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Rotating Assembly upton7 1996-2004 Mustang GT 4 06-30-2009 07:17 PM
engine assembly order ? 93_5.0_JW 1979-1995 Mustang GT 3 06-12-2009 12:15 PM
Need Instructions for Headlight assembly Nick89GT94 1979-1995 Mustang GT 1 05-26-2007 06:50 PM
4.2 rotating assembly, MORE!!! RGR Mustang Parts for Sale and Wanted 4 04-20-2006 08:15 PM
11:00 PM
