getting rid of understeer - Mustang Evolution
Old 07-20-2004, 10:30 AM   #1
Tbird232ci's Avatar
ive been pushing the limits of my car on some backroads, and the car has some pretty nasty understeer, the car enjoys going straight through turns
i read a short article on suspension tuning, and they say running a harder spring in the rear should reduce understeer, and a decent performance alignment would help out
i have some GT springs to put in the rear along with V6 stang springs up front, so it should lower the car, and i found some decent alignment specs for the car, should this help balance the car out, or will it not really help much?
Old 07-20-2004, 01:10 PM   #2
does a rear sway promote oversteer? i think it may but im not sure.
Old 07-20-2004, 02:57 PM   #3
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
You just have to be careful that your car never oversteers (drifting not being considered here) Oversteer is a very unstable condition and therefor very dangerous. This is the primary reason that most cars out there have a high understeer gradient. Neutral steer is ideal of course, but tuning it to that point is expensive and if people tinkered with it they may drive it into oversteer and the car companies don't like that idea.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 07-20-2004, 03:12 PM   #4
I love my oversteer. Every day.
Laser02 is offline   Reply With Quote
Old 07-20-2004, 03:49 PM   #5
well i didnt mean to promote oversteer i just ment to try to get it back to a more neutral state.
Old 07-20-2004, 08:41 PM   #6
Tbird232ci's Avatar
i have turbo coupe swaybars on it, with poly pushings up front, the TC bars are the same as the GT bars front and rear
im not trying to get oversteer at all, id love to get it handling nuetral, but its nearly impossible, so a touch of understeer isnt bad at all
Old 07-20-2004, 09:17 PM   #7
Why would you not want oversteer? It's the funnest thing in the world.
Old 07-20-2004, 11:05 PM   #8
Tbird232ci's Avatar
because its not so fun when youre about to get in an accident, you swerve and your *** end slides out...then youre really screwed
while oversteer can be fun, its not what im looking for, i want to be able to set this thing up to be able to handle on the track, and on the backroads, and when youre having to be gentle on the gas because your *** end slides around, it costs you time
Old 07-22-2004, 07:15 AM   #9
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
If the swaybars you have are the same as a GT then you could get an adjustable swaybar from steeda. That way you could crank the adjustable bar up until the car was more neutral.
and yes a heavier rear sway will increase the tendency to oversteer, thus decreasing the tendency for understeer.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
To get rid of squeaking... crazeflier07 Pre-2005 V6 Mustang 0 08-08-2007 08:14 PM
Lookin to get rid of governor Winger Pre-2005 V6 Mustang 27 05-15-2007 03:33 PM
Really bad understeer problem soon2bfastr232 Pre-2005 V6 Mustang 19 02-21-2005 01:09 PM
Virus i cant get rid of steedav6builder The Bar 10 09-06-2004 09:37 PM
Might get rid of the stang! Help MusclesFromBrussels The Bar 16 10-14-2003 09:35 AM
01:15 PM
