Mustang Cams - Mustang Evolution
Old 07-21-2004, 10:42 PM   #1
ttpancakes's Avatar
Send a message via AIM to ttpancakes
Mustang Cams
What would you guys think are the best cams? Can you have cobra cams on a v6?
ttpancakes is offline   Reply With Quote
Old 07-21-2004, 10:48 PM   #2
01mineralgrey6's Avatar
You only have one cam in the v6. there are different cams for different applications, Im sure that someone can point you in the right direction...I would try PM'ing RGR or Mikael
-Tony
'99 cobra 'vert
Old 07-21-2004, 10:49 PM   #3
ttpancakes's Avatar
thanks 1 cam thats weired
Old 07-21-2004, 10:56 PM   #4
timpryor's Avatar
umm correct me if i'm wrong but i've allways been told that we are SOHC which means we have 2 cam's total one on each side right? because DOHC have 4 total 2 on each side.
this is what i have been told if i'm wrong correct me i'm still learning
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 07-21-2004, 11:05 PM   #5
We have one cam. (1) Uno
Cobra cam will not fit. Only a cam grinded for a v6 will. Check with RGR about a cam
Old 07-21-2004, 11:08 PM   #6
timpryor's Avatar
see this is what i get for listening to my friends
so ours is in the center of the block right?
whereas DOHC vehicles are 2 on each side?
Old 07-21-2004, 11:20 PM   #7
Yes ours is in the center
Old 07-21-2004, 11:25 PM   #8
timpryor's Avatar
ok that clears things up thanks brent I'm learning
Old 07-22-2004, 01:29 AM   #9
tire's Avatar
Send a message via AIM to tire
moving to v6 tech...
v6 is "pushrod" (old school). one cam in the center that pushes up the pushrods that tilt the rockers that move the valves.
gt is single overhead cam (SOHC) meaning one cam is situated above each head.
cobra is same but DOHC, just more cams.
look at the bright side, sohc and dohc'ers regularly spend 450-650 for just the cams themselves. a custom ground pushrod cam willl only run us about 200 for the cam itself. this is why the 2005 OHC will not be worth modifying at all because it'll be so bloody expensive (as if modding a v6 is wroth it, anyways. :p )
that being said, a cam on a 99+ isn't a bad way to go. expect to shell out about 400 though minus the install. good for 15rwhp+. contact RGR and he will send you a questionarre to fill out.
austin
tire is offline   Reply With Quote
Old 07-22-2004, 12:51 PM   #10
2: you have one cam, good old tech pushrod cheaper and easier to work on
Old 07-22-2004, 01:04 PM   #11
97Stallion's Avatar
Nope, we're OHV, Over Head Valves. And yes we only have one cam. If you do your own work, it's gonna cost you only about $170 to do the swap. Say about $120 for the cam and then about $50 for gaskets, and oil, filter and silicone. The real question is what do you really, and honest want to do with your car? Meaning, what is your goal?
Living one day at a time!
Old 07-22-2004, 01:23 PM   #12
tire's Avatar
97S, you forgot new pushrods (80) and springs (100)... and RR's while he's in there would be ideal (300). plus install will be hellacious as tim can't do it yet.
austin
Old 07-22-2004, 02:05 PM   #13
97Stallion's Avatar
Oh ya, I keep thinking about my car. I changed my springs and pushrods ALONG time ago When I did my most recent cam swap, it only cost me $150 or so. But I would screw the pushrods and get adj. Roller rockers instead. Also, I wouldn't just do a cam swap in the first place. If those heads have to come off, then you're gonna need head gaskets and new studs or bolts for that too, so to make things cheaper in the long run, get some ported heads now so you only have to pull them off once. Think of it as you have to pay the garage for pulling the heads, and they're gonna charge you for replacing your springs, so you might as well put that money torwards the new heads instead. It might be a little more, but you're still saving money depending how you look at it.
Old 07-22-2004, 02:22 PM   #14
We can also set you up with a custom ground cam if you'd like.
http://www.extremeeffect.com/38cams.html
Extreme Effects.com is offline   Reply With Quote
Old 07-22-2004, 02:30 PM   #15
Danger Dude's Avatar
austin
Always new springs if you are doing a cam , but if it is a mild cam and the old pushrods check out good use them. But a real performance cam you need new pushrods.
Changing a cam is not for the inexperienced. I have had 2 people I know nick their cam bearings installing the cam and spun the cam bearings out within 2 weeks of doing the work.
Old 07-22-2004, 05:28 PM   #16
yea, i am getting my friend at ford, he has done many cam swaps and rebuilt motors all that, im letting him do every step that i might screw up lol it might cost me a bit but i get to help and learn, and its MUCH better to let him do it than me mess it up.
Old 07-22-2004, 05:30 PM   #17
redline performance aka rpm-mustangs.com has a nice selection of cams, pushrods, roller rockers, springs to choose from. give them a call to and they can hook u up with a nice package for around $350-400. really nice for 15RWHP N/A engine. and 30+RWHP for s/c engines.
bigpomps is offline   Reply With Quote
Old 07-22-2004, 06:28 PM   #18
I have a RPM cam and heads I installed them in 8 hours start to finish but I have 26 years as a mechanic with more tools than most garages
Old 07-22-2004, 06:39 PM   #19
I would be GREATLY honnored if you would come up when I do mine to give me a helping hand, I know Kevin can handle it but the more guys the better the chance i wont fudge something up lol. I am up here near brent so we could all get together. Let me know it will be in a couple few months on a saturday/sunday probably~
just a thought
Old 07-22-2004, 06:44 PM   #20
I would love to My sister in law lives in Huntsville and I could help you while the wife and kids visit the family
Old 07-22-2004, 07:38 PM   #21
slvr2000stang's Avatar
Corey,
That is real nice of you!
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-22-2004, 08:59 PM   #22
I liek gramer
WhiteStang99's Avatar
let me know a date asap and i'll come to learn!
i just need a date beforehand so i can make sure I can come
Old 07-23-2004, 07:23 AM   #23
97Stallion's Avatar
Corey, are you going to bring your tools down by him?
Old 07-23-2004, 07:29 AM   #24
I will bring some of them. Will there be a air Compressor available.I have air tools for disassembly.
Old 07-23-2004, 12:04 PM   #25
97Stallion's Avatar
Ya, air tools make short work of it. An Air rachet, and impact wrench will be the majority of the tools you need. Don't forget to bring your power steering pulley remover and installer if you got one. And definately don't forget the harmonic balancer pulley remover either.
Old 07-23-2004, 12:07 PM   #26
Why the power steering puller just put it off to the side!!! I have a harmonic balancer puller
Old 07-23-2004, 04:04 PM   #27
97Stallion's Avatar
Well how do you plan on getting to the bracket behind the power steering pulley that connects to the waterpump/timing cover? I'm sure you could fit a wrench back there, but I think that just makes it harder that way. I used to just pull off the pulley to get the bracket of, but that got old, so I just left it off completely.
Old 07-23-2004, 04:12 PM   #28
Send a message via Yahoo to plstktnkr2
V 6 tech
I hate to burst a bubble but an overhead cam motor has been around since the Dusenberg J and SJ . (so much for "old school" ) LOL its just more common since machine tooling has completly changed since the introduction of CNC maching and better casting techniques.
Peace
Rick
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 07-23-2004, 05:44 PM   #29
I had the timing cover off in 45 minutes. I took off all the engine brackets including the one that the steering pump mounted to. The engine was was broke down completely including intakes, heads, accessories, timing cover and cam in 1 hr and 30 mins. several hours was used to clean and prep before for reinstallation and about 2.5 hrs was used to actually put everything back to turn key and drive condition.
One note you dont have to remove the radiator. The V6 cam is short so it clears the radiator but you do have to remove the electic fan.
Old 07-23-2004, 08:07 PM   #30
97Stallion's Avatar
Correct, but I take mine off just as a safety procaution. I'd hate to be tring to get the cam out and then it give way and then have the cam go throught the radiator, plus I like the extra 2 or 3 inches removing it gives you. All in all, I just like to play it safe. And Corey you never answered my question about that bracket. How do you remove it with out removing the pulley? Everybody has there own way, I'm just curious to how you do it. It's the final product that matters.
Old 07-23-2004, 08:38 PM   #31
I remove the entire bracket from the motor with the pump attached to the bracket
Old 07-23-2004, 09:06 PM   #32
97Stallion's Avatar
interesting approach.....
Old 07-23-2004, 10:45 PM   #33
Where is this going on at? If it's in Alabama maybe I can provide the refreshments!
Old 07-26-2004, 12:36 PM   #34
What happened to this thread?
I say I'll show up and bring the drinks and the thread dies!
Well I'll just show up anyway and drink my own damn drinks while everyone else suffers and sweats in the heat installing that cam.
But really, let me know and I'll meet some fellow stangers!
Old 07-26-2004, 01:01 PM   #35
lol its probably going to take place in Florence, Alabama
2010 v6 Mustang performance cams?? Camaro Eater 2011-2014 Mustang GT 14 06-04-2010 09:31 PM
Pi cams ?'s 1995procharged 1996-2004 Mustang GT 1 09-06-2009 11:16 PM
4.6l Cams Black00GT 1996-2004 Mustang GT 14 11-17-2008 08:19 AM
Cams ridenmystang 1996-2004 Mustang GT 10 12-12-2006 06:12 AM
Cams megax29 Pre-2005 V6 Mustang 11 04-01-2006 12:07 PM
12:07 AM
