drivtrain questions - Mustang Evolution
Old 07-22-2004, 06:23 AM   #1
tealstangman's Avatar
Region: Nevada
Send a message via AIM to tealstangman
drivtrain questions
I got an 95 auto v6 and about 700 dollars to spend. Im thinking about getting some 4.10's and tlok. Also iv heard about torque converters for autos. Should i get one of those to and a shift kit? thx any help appreciated.
Ryan
2002 red GT mustang
GO:Flows, BBK lowering springs, KYB struts & shocks, Mac straightshot CAI, SCT chip and tune, Accufab Plenum 70mm, Motive 4.10's
Show:18x10 & 18x9 Bullitt Deep Dish Chrome Wheel's
295/35/18 & 265/35/18 Michelin Pilot Sport PS2's
tinted windows, billet grill
tealstangman is offline   Reply With Quote
Old 07-22-2004, 06:51 AM   #2
Danger Dude's Avatar
A PI torque converter is around $600. I would instead get the 4.10 gears, tlok and shift kit first it is one of the best mods for the money period!!!!!!
Old 07-22-2004, 12:18 PM   #3
Monkey's Avatar
a used PI is about $600. A brand new one will run you about 700 or so plus ~$200 for install. It is an amazing mod, but get some 4.10s with tlock and a 23 tooth speedo gear installed for that money and you'll feel a large difference as well
Old 07-22-2004, 03:02 PM   #4
Region: Nevada
Where should i buy the gears and tlok. Aslo where do i get the instal kit for the gears?
Ryan
2002 red GT mustang
Old 07-22-2004, 03:05 PM   #5
Get the speedcal not the speedo gear. Its accurate
Old 07-22-2004, 03:50 PM   #6
Region: Nevada
Ok. But where should I buy the gears and tlok. Also I need the install kit to. Where do i buy that?
Ryan
2002 red GT mustang
Old 07-22-2004, 04:18 PM   #7
tire's Avatar
Send a message via AIM to tire
www.gefracing.com
you can't install it correctly yourself. install will be about 200-350 depending.
austin
tire is offline   Reply With Quote
Old 07-22-2004, 04:25 PM   #8
Gef is has good prices but they are often time out of tloks. When I ordered mine I ended up getting one from West Coast Differential at www.differentials.com because GEF was out They have about the same prices
I will mention one thing is GEF's return policies suck. Paul Greenflash00 ordered a 4.10 ring and pinion set and had it installed and it made a racket. he took it back to the shop and tried for 2 days to get it right. The shop said it was warped. Paul contacted GEF and they told him once itr was installed they would not take it back but they would give him a 10% discount on the next one he bought???? That sucks. He went to Midwest and ordered one and thwe shop installed it with no problems.
Old 07-22-2004, 04:49 PM   #9
Region: Nevada
Why cant i install it myself?
Ryan
2002 red GT mustang
Old 07-22-2004, 04:51 PM   #10
tire's Avatar
requires a measuring tool costing 150 and you would have no idea what to measure or how. trust us on this, get it installed.
Old 07-22-2004, 05:11 PM   #11
Region: Nevada
I live in Las Vegas, does anyone know of a place here to get them installed? Also how much am i looking to spend?
Ryan
2002 red GT mustang
Old 07-22-2004, 05:42 PM   #12
tire's Avatar
Originally Posted by tire
www.gefracing.com
austin
read.
you'll have to ask around. find a speedshop and ask them. do not go to ford, under any conditions, or any dealership.
Old 07-22-2004, 06:12 PM   #13
Region: Nevada
yeah I'd never take take it too ford. I'll see if my friend can help me out he works at factorx. well thx for all your help. Cant wait to get my gears and tlok.
Ryan
2002 red GT mustang
Old 07-25-2004, 08:36 PM   #14
Region: Nevada
Would it be a better idea just to go for the 8.8 if im planin on adding a sc? Also does the 8.8 directly swap out with the 7.5 and can i do that myself. but then do i still have to have someone install gears?
Ryan
2002 red GT mustang
Old 07-27-2004, 01:51 AM   #15
Region: Nevada
:feedback: I want to get the 8.8. Does it come with the gears already installed and can i do this myself??? Will it fit on my v6 without any mods. also where should i buy it?
Ryan
2002 red GT mustang
Old 07-27-2004, 02:04 PM   #16
Monkey's Avatar
some will come with gears already installed. Some will have them taken out to save weight on shipping. If installed, then you can installed the rear end yourself. It will bolt up directly very easily.
www.speedconcepts.net is where you can buy it
Old 07-27-2004, 02:21 PM   #17
Region: Nevada
thx man
Ryan
2002 red GT mustang
Old 07-27-2004, 02:27 PM   #18
Region: Nevada
Does anyone know of a place where 4.10's are already installed in the 8.8?? or would the 3.73 work ok since i have an auto
Ryan
2002 red GT mustang
Old 07-27-2004, 02:31 PM   #19
you want 4.10's trust me. Not sure if anyone sells them with 4.10's already installed.
Old 07-27-2004, 02:32 PM   #20
also realize you are going to need a chip and a speedcal if you get the 8.8 and upgraded gears
Old 07-27-2004, 02:51 PM   #21
4.10s arnt that bad, not nearly as bad as i thought
Old 07-27-2004, 02:58 PM   #22
Zim
You want to **** me?
Zim's Avatar
4.10s are sweet
I like toys
Old 07-27-2004, 04:40 PM   #23
Region: Nevada
how much power can the 7.5 handle?
Ryan
2002 red GT mustang
Old 07-27-2004, 04:55 PM   #24
Quite a lot. There are people well over 300RWHP still using the 7.5. The fact is the 7.5 is more than enough to handle any N/A application and will hold up well with Nitrous or Supercharger. The key is going beyond 300HP you should avoid using Drag slicks. The use of street drag radials is OK.
Key is take car of the stock rear end and it will be OK. Remember if you get a Tlok change the lube and add friction modifier every 18 months or so. People seem to overlook changing the rearend lube. Especially with 3.73 or 4.10 gears.
I have never understood why people neglect Rearend lube, Brake fluid or Power steering fluid. Brake fluid absorbs close to 4% water every year and in 5 years your brake fluid is milky and nearly 20% water. Power steering is not nearly as bad a brakes but in 5 years you can be 10% water and is a major cause of the classic Ford Power steering pump noise.
Old 07-27-2004, 05:59 PM   #25
my power steering made noise from 5 miles on the clock till now but you are very true change your fluids lol, how hard is it to change the powersteering fluid?
also if you ever really plan to drag race the car alot get an 8.8 its not much more if any more expensive, i broke my 7.5 with just bolt ons on street tires with 2.1 - 2.2 60ft but if you buy only new parts and get a pro to put them in i belive any non slick 2.0 ~ 60ft will hold up fine with the 7.5
Old 07-27-2004, 11:12 PM   #26
Region: Nevada
Alright I dont need the 8.8. I'll stick with what i got and get the 4.10's and tlok. Thanks for all your input it helped alot.
Ryan
2002 red GT mustang
Old 08-02-2004, 12:48 PM   #27
before you order parts go price around and see what installs are gonna run you along with what kind of warranty they offer for gear whine and wear or install mishaps, along with asking them if they know how to set the backlash, pinion depth and all that if they dont know what those are... chances are they are not the shop for you, you might have to talk with the guy that will do the install to find out not the clerk, also i would pay a buziness to do it so you have their liability, paying a friend is nice but if they break he wont be responsible and all that.
5.0 and 4.6 questions Cblaze 1979-1995 Mustang GT 18 01-12-2011 10:01 PM
I need help with a few questions xjlxking 2005-2010 Mustang GT 14 02-22-2010 01:38 PM
two questions..help! 02whitemustang Pre-2005 V6 Mustang 7 08-28-2006 10:51 PM
Questions DMAC Pre-2005 V6 Mustang 5 08-30-2004 10:19 PM
gt take-off questions blk2kconvstang Pre-2005 V6 Mustang 7 03-22-2004 08:02 AM
03:24 AM
