caster camber plates - Mustang Evolution
Old 12-18-2008, 04:44 AM   #1
J & M or MAXIMUN MOTORSPORTS??
Which is better?
carlosc is offline   Reply With Quote
Old 12-18-2008, 04:54 AM   #2
Re: caster camber plates
Can't go wrong with Maximum Motorsports
Old 12-18-2008, 06:26 AM   #3
1234's Avatar
Maximum Motorsports ftw
Old 12-18-2008, 08:16 AM   #4
on the 05+ ive not had any direct dealing but maximum motorsports has great quality items
Old 12-18-2008, 08:32 AM   #5
Herbstang's Avatar
Maximum Motorsports
Old 12-18-2008, 02:25 PM   #6
The Darkside's Avatar
ok im going to do it, im going to ask the dumb question.......
what in the world are caster camber plates? and what do they do?
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 12-18-2008, 02:27 PM   #7
CC plates are the plates on the top of your strut towers where your front struts come up through into your engine bay.
What they do is they allow you greater adjustment to fine tune your front wheel alignment. The stock plates offer limited adjustment, so when you lower your car, you may or may not be able to get your caster and camber right. For example, my car is out of spec because the stock plates will not allow enough adjustment.
When I get the MM plates, I will finally be able to get things within spec.
Plus, the aftermarket ones look a ton better than stock.
Old 12-18-2008, 02:31 PM   #8
ok that gives me a better understanding, thank you. but now i have another question, does the adjustment help in the way your ride handels?? this is a whole new world that i know nothing about. Power addatives i know, suspension im like president bush in the oval office--clueless lol
i bleed Race fuel!
Old 12-18-2008, 02:35 PM   #9
Yes, it will help the way your car handles if it is out of spec currently. It will help you get your allignment right so you don't get quite as much road steering. I get a ton of that because my wheels are tilted in a little too much. The road I live off of will stear my car something fierce.
It won't change the way the suspension handles bumps and such, but it will help your stearing, tracking, and tire wear if you are currently out of spec. But, like I Said, they are also a nice under hood dress up item.
Old 12-18-2008, 02:41 PM   #10
very intresting, i feel like i should have learned all this. im not happy with the way my car handles. it doesnt take bumps well as it is and i swear it pulls to the left on its own somtimes...that could be alignment as well.
thanks man.
i bleed Race fuel!
Old 12-18-2008, 02:45 PM   #11
It could also be bump steer, which is not cured by plates....but by installing a bump steer kid from steeda or upr or other places.
And so you know, bumpsteer is when your wheel changes allignment as the suspension travels. The bumpsteer kit allows the wheel to maintain it's verticle allignment thru the range of motion.
Old 12-18-2008, 02:52 PM   #12
wow!! all news to me. dam thanks. ill remember that.
i bleed Race fuel!
Old 12-18-2008, 05:27 PM   #13
how is the best way to put the 2 shorts and 2 long spacers in the bearing plate ???
Old 12-19-2008, 07:22 AM   #14
I have mine set for maximum handling alignment (but its all speculation lol you have to get on a track and see what works for you and your car) and I can tell a difference.
Old 12-20-2008, 05:25 PM   #15
Which is better?
I've always had good luck with Maximum Motorsports products. I'm currently not running their C/C plates but they do make a quality piece.
This was the biggest problem I had after lowering my car. Even after getting the alignment put into spec I was having issues with the car wanting to steer out on a hard turn. Put in a bumpsteer kit and the difference was night and day.
You have to remember, most of us are pushing our stock suspension limits just with the tires we are running. I'm running a 275 on the from with little sidewall and a 295 on the back with a little more sidewall than the front. This is putting an enormous strain on the stock suspension components just in normal driving, hence the reason a car with much wider tires will "track" with the grooves on the road. The stock steering setup is not designed to control wheels and tires with these weights and sizes.
Probably one of the next suspension pieces going on my car will be something to beef up the steering components in the car.
How much is your car lowered?
Also, which kit are you attempting to install?
If you would like a good set of alignment specs for the shop to work off of I can give you mine. I have my car set at the maximum specs recommended by Kenny Brown, and they are nowhere near the stock limits lol.
Old 12-20-2008, 07:05 PM   #16
ford racing c springs, tokico shocks / struts ( blue ones), motorsports c/c plates
Old 12-20-2008, 07:48 PM   #17
You wouldn't happen to have the kit number handy would you?
Old 12-20-2008, 07:51 PM   #18
Ok, you should be running:
1 short spacer under the plate
1 short and 2 longs on top of the plate
Old 12-20-2008, 09:28 PM   #19
but , can i close the hood without problems with this setup?
Old 12-20-2008, 11:19 PM   #20
You should be able to, that's the setup I ran with C springs on my V6 car. Take a piece of playdough and set it on top of both struts and slowly shut the hood till it latches. Then open it back again, if the playdough has been pressed down it's too high.
Old 12-21-2008, 08:50 AM   #21
if that the case can i pot one short and one long below and one short and one long above??
i will not cot the springs like you do, so this setup may work?
Old 12-21-2008, 04:33 PM   #22
That setup is for stock suspension height. Even with non-cut C springs you will probably have to do the way I said since it will be lowered about .75 inches.
Just use some playdough or something pliable and slowly shut the hood. If it's too high you'll know.
Old 12-21-2008, 07:38 PM   #23
if that happen ( the strut too high) what can i do??
Old 12-21-2008, 08:51 PM   #24
If the top of the strut is too high...put more spacer under the plate. If it's too low you will have greatly reduced suspension travel and a likely dangerous situation.
Old 12-22-2008, 04:17 PM   #25
You are setting up your car about the same as mine is except I used the J&M plates. There was plenty of room under the hood for the struts...I had at least an inch of room.
'02 vert V6...Pioneer F900bt H/U. White gauge and HVAC controls overlays. Billet headlight and HVAC control knobs. Dual band D-Star HAM radio. Chin spoiler. Projector headlights. 17" white bullitt wheels, 9" in front, 10.5" in the rear. Nitto 555's. 275's in the front and 315's in the rear. Ford Racing "C" springs with Tokico Blues at all 4 corners. CAI and UDP. True dual exhaust, with magnaflow's, H pipe, chrome turndowns. J&M 4 bolt camber/caster plates. 3:73 gears. SCT X3.
Gerry52 is offline   Reply With Quote
Caster Camber Plates 04SonicBlueGT 1996-2004 Mustang GT 3 11-20-2009 07:34 AM
caster camber plates! monstermustang 1996-2004 Mustang GT 4 04-16-2009 10:42 AM
Caster/Camber Plates...will they be a problem with this? Joel5.0 1979-1995 Mustang GT 4 10-22-2005 04:36 PM
09:32 AM
