Pulsing in Pedals - Mustang Evolution
Old 07-24-2004, 04:45 PM   #1
Pulsing in Pedals
Hi All,
Not sure where this one goes, so I picked suspension/drivetrain.
This morning I woke up and found that I had a flat tire on the rear driver side. The tires were getting old, so maybe it was a sign to get new tires, which I did. On the way over to the tire shop, riding on the donut, I felt a pulsing/rattle from the brake&clutch pedals as I slowed down (it only got noticeable are 15 mph). I figured it had something to do with the donut. Sadly, even with the new tires, I get the same pulse - it's never at high speeds though. They checked the alignment at the shop when they put on the new tires - everything checked out. I adjusted the clutch, which took care of the rattling sound from that pedal - but the brake still is strange.
Not sure where to go on this one - new front rotors/pads about 4000 miles ago. Rear brakes are still visibly ok (but I'm not a brake specialist).
Any thoughts? Sorry for the long post.
njstang97 is offline   Reply With Quote
Old 07-24-2004, 05:11 PM   #2
01mineralgrey6's Avatar
It sounds almost like there may be air in the brake lines??? Do you know if the brakes where bleed after replacing them?
-Tony
'99 cobra 'vert
Old 07-24-2004, 05:52 PM   #3
the brakes could need bleeding, but you surly would have noticed this before 4k miles, its worth a shot though.
If your rotors were messed up you would feel it when braking but the steering wheel would probably shake also.
Old 07-24-2004, 06:03 PM   #4
Danger Dude's Avatar
rotors are in need of turning or replacing.
Old 07-24-2004, 06:45 PM   #5
or you got a troll in your car and he/she (but really girl trolls dont get in cars they are more like moped and bird nest type trolls) likes to mess with your brake petal, its a 50/50 chance thing, either what i said or corey just check for both. OH, If you do find a troll dont let him bit you, cuz it will hurt.
Old 07-26-2004, 11:32 AM   #6
Apparently, it was the troll. I was driving to work today and it seems like the car healed itself. Nice! The troll was just waiting for the rain to pass over I guess.
Old 08-01-2004, 10:23 AM   #7
spector, are those rotors on backwards?
All pigs are useless!
widowvirgin is offline   Reply With Quote
Old 08-01-2004, 02:18 PM   #8
Tbird232ci's Avatar
my car does the same thing when the brakes get a bit warm, the pedal will pulse under braking, the car is in need of front brakes
Old 08-10-2004, 09:08 AM   #9
Smile
The rattle is back. I took it to the dealer to see if it was either the TOB or the clutch itself - neither was the case (AND they didn't charge me for looking at it). Good news that I don't need a new clutch, bad news that they didn't see what was wrong.
I find that after shifting, lifting up lightly on the clutch pedal eliminates the rattle too (along with holding it down lightly). I think that the quadrant may not be right, so I got a new UPR clutch cable/quadrant/adjustment nut. If it turns out not to be the problem, at least I have a new UPR clutch cable/quadrant/adjustment nut.
Is there a nice step-by-step installation out there for replacing the stock stuff with adjustable aftermarket (I'm thinking that the instructions would be the same for UPR/Steeda/whoever else). Help is always appreciated! Thanks!
Old 08-11-2004, 04:49 PM   #10
the installation is very straight forward, if the upr looks just like the steeda then i would say to use the same instructions.
Old 08-12-2004, 05:52 PM   #11
if lifting up on the clutch petal or putting a little pressure on the clutch petal makes the noise go away then it IS the throw out bearing, if you act fast enough and get a quadrent and firewall adjuster you can take the slack out of it and perhaps save you the price of a new throw out bearing..... thats the problem for sure though.
Old 08-12-2004, 06:54 PM   #12
agreed.
Old 08-12-2004, 09:39 PM   #13
I am the throw out bearing king, I went though 4 underwarranty.... ford can kiss my white ***! definatly get a quadrent and adjuster if they are BSing you about the throw out, if you can get it to tick for them they cant deny its not it.
Old 10-05-2004, 07:15 AM   #14
Just as closure - the quadrant/cable/firewall adjuster solved the problem - no more pulsing, no more noises.
Pulsing Woofer StreetRacer4371 Mustang Audio & Video 7 05-05-2005 10:10 PM
Pedals for everyone!! 97Stallion The Bar 14 11-15-2004 07:03 PM
Who got their pedals already? 97Stallion The Bar 19 11-01-2004 06:53 AM
Bullitt pedals 97Stallion Mustang Parts for Sale and Wanted 34 10-27-2004 08:28 AM
Rice Light-Up Pedals Gone -- Steeda Pedals In! Shahrum Mustang Audio & Video 21 06-14-2004 12:18 AM
11:59 PM
