Squeaking Noise - Mustang Evolution
Old 07-26-2004, 02:01 PM   #1
Unhappy Squeaking Noise
OK...my friend came over this morning so i could show my friend my new exhaust system (GT takeoffs with 40 series flows). anyway, when i went to start the car. i pushed the clutch in and there was this loud squeak comin from the car. i was like WTF. so i let the clutch out and push it in again. same sound. so i had my bro come out and push the clutch in while i listened and there was the same sound. is my throwout bearing starting to go or something, cuz it jsut started doin this this morning, or at least i never noticed it before. also, wut exactly does the throwout bearing do. is this something i should get looked at right away or can i leave it for a little while?
joekool9 is offline   Reply With Quote
Old 08-02-2004, 09:54 PM   #2
a throw out bearing is a part of the cluch movement in engaging and disengaging the pressure plate and the disc. if it is your throw out bearing you might as well get a whole new clutch becuse to get a new throw out bearing it requires you to take down the tranny and take out the clutch. it would be cheaper in the long run. when you get a new clutch your flywheel needs to be resurfaced so go the extra mile and get a billet flywheel and let loose some hp in your engine as well. this is of course if you have the dough. i have a spec stage 3 in my car. it works very well but i recomend a stage two.
bigpomps is offline   Reply With Quote
Old 08-03-2004, 12:03 AM   #3
how is the stage 3. i was looking into a stage 2 or 3 when my clutch goes.
Old 08-03-2004, 10:38 AM   #4
97Stallion's Avatar
Double post:mod: :locked:
Living one day at a time!
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 02:03 AM
squeaking sound from engine midnightrider_s Pre-2005 V6 Mustang 5 10-12-2009 08:39 AM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-30-2008 12:24 AM
To get rid of squeaking... crazeflier07 Pre-2005 V6 Mustang 0 08-08-2007 09:14 PM
can't stop doors from squeaking stangracer Mustang Audio & Video 11 11-11-2003 12:08 PM
01:08 PM
