new brakes ??? - Mustang Evolution
Old 08-02-2004, 05:40 PM   #1
new brakes ???
I want to get new brakes for my 2000 V6 what are your suggestions?...I have 18" rims
chevykiller is offline   Reply With Quote
Old 08-02-2004, 06:42 PM   #2
13" Cobra brakes
http://www.mustangtuning.com/cobrabrakes.html
Old 08-02-2004, 06:46 PM   #3
SquirrelNutz154's Avatar
Send a message via AIM to SquirrelNutz154
Agreed. I'd upgrade the rotors though.
SquirrelNutz154 is offline   Reply With Quote
Old 08-02-2004, 06:47 PM   #4
You do upgrade the rotors with the 13" Cobra kit....
Old 08-02-2004, 06:56 PM   #5
I'd get them drilled and slotted though. I know those rotors are upgraded over stock, but I'd go the extra step and upgrade to drilled and slotted rotors.
Old 08-02-2004, 06:57 PM   #6
Drilled and Slotted offer very little over just slotted other than looks
Old 08-02-2004, 07:02 PM   #7
I alweays heard that they keep them cooler, which leads to very very slightly better stopping, but much longer life and less warping. Never done any tests though, so I don't really know.
Old 08-02-2004, 07:06 PM   #8
You wont notice a difference in normal everday driving. Plus drilled rotors have been known to crack under heavy use.
They do look sweet however and I will be getting them when I upgrade.
Old 08-02-2004, 07:07 PM   #9
Interesting. Definitely right about them looking sweet.
Old 08-03-2004, 09:49 AM   #10
Danger Dude's Avatar
If I was you I would keep the calipers you have. The PBR Calipers on your car are 2 piston calipers just like the cobra. As a matter of fact PBR makes all the Calipers for the mustang including the V6, Cobra and Mach 1. You could have them powdercoated any color you want. I would consider getting Slotted Rotors to improve braking. I went from single pistons on my 98 to PBR dual pistons off a 99GT and it made a wrold of difference do to the increase in contact breaking area. Going from your calipers to Cobra cailpers will not be noticeable much at all in notmal driving. Also when you have the brakes done change the Brake fluid. You would be suprised how changing the brake fluid will improve braking and help eliminate brake fade and spongy brakes.
Old 08-03-2004, 12:29 PM   #11
97Stallion's Avatar
You took the words right outta my mouth. I upgraded to the Dual Piston and I think it was one of the best mods I've done yet.
Living one day at a time!
Old 08-03-2004, 12:41 PM   #12
Monkey's Avatar
Brembo brakes, 4 piston up front, 2 in the rear.
Old 08-03-2004, 01:02 PM   #13
97Stallion's Avatar
Brembo's are over rated and way too expensive. Unless you're getting them for dirt cheap, I wouldn't waste the money.
Old 08-03-2004, 02:23 PM   #14
Monkey's Avatar
I was just kidding. They are good brakes, but I wouldnt spend the $3000 for the mustang kit
Old 08-03-2004, 06:19 PM   #15
oem cobra 01 up brakes adn rotors front set up only, it will do all the stoping you will ever care for.
BRAKES DMAC General Mustang Discussion 5 02-18-2008 08:26 PM
Brakes mongolchuck 1979-1995 Mustang GT 1 01-12-2008 03:49 PM
brakes.. Fishers Stang Pre-2005 V6 Mustang 14 01-13-2005 06:32 PM
Brakes V6STANG007 Pre-2005 V6 Mustang 23 10-13-2004 04:32 PM
Brakes....... SexyStang Pre-2005 V6 Mustang 3 05-05-2003 09:03 AM
02:41 PM
