problem with ported upper installation. HELP!!! - Mustang Evolution
Old 08-06-2004, 10:40 AM   #1
Zim
You want to **** me?
Zim's Avatar
problem with ported upper installation. HELP!!! **FIXED!!!**
Ok yesterday me and jeremy (Horse) put my ported upper on my car. We got everything back together and started the car up... started fine then went down to where it idles and started sputtering and dropping to like 200 rpms and eventually died. Well we looked under the hood and realized we forgot to reconnect the egr pipe to the egr valve... so after an annoying fix with that we finally got it put into place and started it again. It did the same thing. This time though there's a high pitch whistling sound and itll sit there and idle rough for a while, but takes longer to actually stall the car. So yesterday i was driving it cause i thought id just need to keep the idle RPMs up so the car wouldnt die, but as im driving it i would be driving and then lose all repsonse from the throttle... it even stalled out on me once so i just took the car home to let it sit and drove my dads the rest of the night. IM not really sure whats wrong here... the only thing that me and jeremy could come up with is that maybe the metal gakset that goes between the EGR valve and the upper intake is shot and is creating a bad exhaust leak so im going to try replacing that today. Does anyone else have any suggestions on what might be wrong? Im pretty sure ive connected all the vacuum lines but Ill be double checking that today as well. Any ideas?
I like toys
Old 08-06-2004, 10:52 AM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
I'd double check all the vacuum lines and sensor connections. Is the gasket between the upper and lower good? It sounds like a bad vacuum leak, to me.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 08-06-2004, 11:00 AM   #3
Zim
Zim's Avatar
yeah i replaced both the gasket between the upper and lower, and the throttle body gasket
I like toys
Old 08-06-2004, 11:14 AM   #4
Zim
Zim's Avatar
Corey Any Ideas???!!!
I like toys
Old 08-06-2004, 12:22 PM   #5
Danger Dude's Avatar
They is a gasket that goes between the EGR and the upper intake. you might have a EGR problem. You could have the vacume tubes hooked up wrong. Tke the vacume tube off the saucer shaped vacuum cannister and hold your finger over the vacuum line and see if it changes anything. Next chech the cannister by when it is cold see if it is holding a vacuum take a hose on it and use your mouth to create a vacuum ( if you dont have a Vaccume tool) and see it it holds.
Did you use your EGR from your car???
Old 08-06-2004, 12:25 PM   #6
Zim
Zim's Avatar
yeah i used the EGR from my car, just swapped the intake over. Im gonna go try those two things right now... but before i did this i wasnt having any problems with my egr, why would it act up now?
I like toys
Old 08-06-2004, 12:35 PM   #7
You just never know
Old 08-06-2004, 12:35 PM   #8
Zim
Zim's Avatar
ok i think i found the problem. That line that connect to the underside of the intake was loose, i pushed it in as much as i could wihtout compeltely taking of the intake again and it does run better.. it doesnt stutter out and die anymore. Now i just gotta make sure that thing is nice and tight on there. I dont know how that cme off, i specifically remember putting it on there nice and tight. Basically i just listened where the noise was coming from and stuck my fingers under there to see if i could feel anything. Sure enough it felt loose and i could feel a vaccuum suck my finger against that area so now i just have to get it snug on there. Thank god...
I like toys
Old 08-06-2004, 12:36 PM   #9
Zim
Zim's Avatar
im gonna run down to the gas station and see how it does on a short drive. ILl be back and ill update you on how it is
I like toys
Old 08-06-2004, 12:49 PM   #10
Zim
Zim's Avatar
alright.. well it doesnt stutter out and die anymore but it still isnt driving right. If im goin faster than like 35mph its like the transmission puts itself into neutral and just wont give any reponse to the engine. Alsmost like my car turns off, then itll start responding to the throttle again out of nowhere. This frickin blows... god dammit
I like toys
Old 08-06-2004, 01:05 PM   #11
That almost sounds like a Throttle Position Sensor. Did you use a different T/B
Old 08-06-2004, 01:10 PM   #12
Zim
Zim's Avatar
not a different one no... we half shafted the TB when we took it off though
I like toys
Old 08-06-2004, 01:12 PM   #13
Zim
Zim's Avatar
the thing is its still whistling under the hood when the throttle is just hardly engaged... its a pretty loud whistling noise and i just cant seem to tell where its coming from. This is really gettin me discouraged, now i have to wait longer to head back to school cause im gonna have to take my damn car into a shop.. god dammit this blows
I like toys
Old 08-06-2004, 02:11 PM   #14
have someone run your engine up while you spot the leak .. it sounds like a throttle sensor to me, electrical parts are real sensitive sometimes and simply moving them around can screw them up. could have loosened the connection while you had the tb off
http://www.mustangevolution.com/foru...ine=1089763695
Originally Posted by jimmy_beaner
This is America, where every vote counts, unless it's a vote for a Democrat.
thirstymate is offline   Reply With Quote
Old 08-06-2004, 02:12 PM   #15
that would be why it only happens sometimes
Old 08-06-2004, 02:14 PM   #16
also is it a cut and weld intake.. if so they could have missed a weld
dont know if you have the time but if it is a cut and weld intake id take it back off and pressure test it. if it leaks, then thad be your whistle
Old 08-06-2004, 02:14 PM   #17
Zim
Zim's Avatar
no its not cut and weld...
I like toys
Old 08-06-2004, 02:26 PM   #18
Zim
Zim's Avatar
i think im just gonna bite the bullet and take it to a stupid shop.
I like toys
Old 08-06-2004, 02:42 PM   #19
97Stallion's Avatar
Mike, well I would try first, you might have gotten the idle air control and the EGR connectors mixed up, so that could be a problem. So it's not relaying any info to your DFPE? or your IAC. You could try that cause they look the same, and finally I don't think anything is really wrong with the intake or your vaccum, maybe you half shaft and polished something too much? But I'd be willing to bet you got those connectors mixed up.
Living one day at a time!
Old 08-06-2004, 02:45 PM   #20
Zim
Zim's Avatar
can you tell me what those two look like? are you talkin about the things that plug onto the sensors?
I like toys
Old 08-06-2004, 02:51 PM   #21
97Stallion's Avatar
yup, i sure am, it should take about a whole 2 second to switch them. The question is do you know what two I'm talking about?
Old 08-06-2004, 02:55 PM   #22
97Stallion's Avatar
Just in case you don't know, and I'm just doing this just in case to make it easier, but on top of the Throttle body is the IAC that the connector and the device that bridges between the Throttle body and the intake is the DFPE, look for a connector on that that looks just like the one from the IAC. And finally there's another connector on that device, make sure it's gray and not black, ok?
Old 08-06-2004, 02:58 PM   #23
Zim
Zim's Avatar
which one gets the gray one? The IAC or the DFPE?
I like toys
Old 08-06-2004, 03:06 PM   #24
Zim
Zim's Avatar
the two connectors that i see that look alike are on that thing that bridges from the TB to the intake, and that sensor thats not directly on top of the TB, but rather sits kind of on the side closest to the firewall. Are those what youre talking about?
I like toys
Old 08-06-2004, 03:11 PM   #25
Zim
Zim's Avatar
here... are these what youre talking about?
I like toys
Old 08-06-2004, 03:20 PM   #26
97Stallion's Avatar
If that picture was taken right now, then those are in the right spots, I marked the other two, check those. They should look the same.
Old 08-06-2004, 03:21 PM   #27
Zim
Zim's Avatar
yeah i just went out and took that... i dont know wtf the problem is and its really pissin me off
I like toys
Old 08-06-2004, 03:22 PM   #28
97Stallion's Avatar
One other thing, the bottom of that DFPE thing is suppose to have 2 hose attached to it coming from the EGR tube, are those attached to that DFPE device?
Old 08-06-2004, 03:24 PM   #29
Zim
Zim's Avatar
yeah theyre on there
I like toys
Old 08-06-2004, 03:24 PM   #30
97Stallion's Avatar
OK, let me study the picture for a minute, maybe it's one of those too obvioius things
Old 08-06-2004, 03:33 PM   #31
97Stallion's Avatar
hmm, i can't find anything obviously wrong from that pic. Too bad you didn't move with me, if I was in Omaha I'd be able to help ya in person. Can you maybe take more pics maybe of the whole engine bay and one from the other direction. And I've never worked on 94-95 V6's but I know there intakes only have one huge vaccum port and the 96-98's have 2. Are you guy short a vaccum line, or did we get added something? I've always wondered this.
Old 08-06-2004, 03:35 PM   #32
Zim
Zim's Avatar
im not sure what the deal with it is, but this intake came off another 95 so there shouldnt be any extra vacuum tubes or anything anywhere on it. Let me see if i can get you some video of how it sounds... gimme a couple mins
I like toys
Old 08-06-2004, 03:39 PM   #33
Zim
Zim's Avatar
ok i got video, im uploading them and ill let you know when theyre done. The paths will be
www.ponypanels.com/zim/MOV00434.MPG and
www.ponypanels.com/zim/MOV00435.MPG
I like toys
Old 08-06-2004, 03:41 PM   #34
Zim
Zim's Avatar
its gonna be about 8 more minutes
I like toys
Old 08-06-2004, 03:48 PM   #35
Zim
Zim's Avatar
ok videos should be up... check it out
on the first one you can hear the whistle as it dies for sure
I like toys
Ported and Polished lower and upper intakes danstang Pre-2005 V6 Mustang 15 07-19-2005 02:00 PM
Ported Upper or Lower first? ntc432 Pre-2005 V6 Mustang 20 05-06-2005 07:04 AM
Stage 3 Ported Upper Intake from RGR Brent Mustang Parts for Sale and Wanted 4 02-08-2005 12:56 PM
Powdercoated & Ported 99+ Upper Intake stangin99 Mustang Parts for Sale and Wanted 5 04-28-2004 10:29 AM
Pro Ported upper intake plenum on my 4.6L 99+.... Rick0636 The Bar 8 01-15-2004 07:43 AM
10:44 AM
