front wheels - Mustang Evolution
Old 12-27-2008, 06:08 PM   #1
front wheels
ok guys im ready to buy my new wheels for my v6 2001 . bullit chrome 17
17 x 10.5 with 315 35 17 back and not sure about the front wheels
right now i have torq trust II 07 x 9.5 all around with 282 40 back and 245 45 front, in the front at full look the wheel rub with the sway bar, i can turn the steering wheel just 1 1/4 before rubbing,
i dont know if will be the same with 17 x 9 with 275 40 tires
what do you guys recommned, 17 x 8 with 245 45 front with maybe 1 / 2 spacer for take out the wheel a bit just for looks,
or 17 x 9 (275 40 ) cant rub anything or 17 x 9 (275 40 ) with lock limiters??
i really dont know what to order for the front
any of you have 17 x 10.5 and 17 x 8 front , ?? how it looks??
any advice please , i dont wanna buy the set of wheels / tires and donk like them or rubbinh issues
carlosc is offline   Reply With Quote
Old 12-28-2008, 01:13 AM   #2
Re: front wheels
Old 12-28-2008, 04:33 PM   #3
Re: front wheels
Get the 17x9s with the 275s. They look way better than 17x8s and only rub at full lock.
Old 12-28-2008, 05:16 PM   #4
Re: front wheels
how much can i turn my steering wheels with 17 x 9 with 275 ??
with thw wheels i have i can turn thw steering wheels just 1 1/4
Old 12-28-2008, 05:50 PM   #5
Re: front wheels
You should be able to turn all the way without any serious rubbing with the 17x9s. You may feel it contact the fender well but then just release the steering wheel a little bit.
Your current rims are a half an inch wider than the other rims, so you can't give them full lock. 1 1/4 sounds right for the 17x9.5s
Old 12-28-2008, 07:45 PM   #6
Re: front wheels
so you think that with 17 by 9 with 275 i can turn the sterrieng wheel at leats 1 1/2?
Old 12-28-2008, 08:16 PM   #7
Re: front wheels
Yeah, I can without rubbing.
Old 12-29-2008, 07:13 AM   #8
Re: front wheels
I would go 17x8 in the front if the offset is where you want it vs the 17x9 so you can buy a 245 or a 255 tire (255 protects the lip better but is a little taller due to the 40 sidewall percent) and you wont have issues rubbing. The 9 wide will rub a little it depends on offset (5.95 or 6.11 offset will work fine) I mean its not horrible just a little rub~ dont full lock it
Old 12-29-2008, 08:28 PM   #9
Re: front wheels
Yah pretty much follow what spector said, summed it up pretty well, i suck at doing that.
Old 12-29-2008, 10:29 PM   #10
Re: front wheels
this is the specs for the front wheels :
17x8
Back Spacing: 5.72" (145mm)
Offset: +30mm (1.18")
Bolt Pattern: 5x4.5" (5x114.3mm)
or
17x9
Back Spacing: 5.94" (151mm)
Offset: +24mm (0.94")
the 9's rub at full lock in the swaybar or in the fender??
Old 12-30-2008, 08:58 PM   #11
runvsofthisbull's Avatar
Re: front wheels
I have 18x9 with 275/35/18 toyo's at all four corners and I don't rub unless I'm turning in circles...lol. 275's are best size for 9 inch width rim.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Looking to trade my wheelzz saleen wheels!! Wtt 4 blk wheels saleenman Mustang Wheels & Tires 12 08-27-2009 11:41 AM
front brakes 96bluegt 1996-2004 Mustang GT 2 05-21-2007 08:20 PM
any 99+ front bumper stangracerjeff Mustang Parts for Sale and Wanted 1 12-12-2004 09:55 PM
Stage 3 roush front OR keep 01 cobra front? SpectorV Mustang Audio & Video 16 11-27-2004 12:17 AM
11:36 PM
