swapping a C5 - Mustang Evolution
Old 12-28-2008, 10:45 PM   #1
Region: New Mexico
Question swapping a C5
My '83 Mustang (3.8L) C5 transmission needs repair and I am looking at swapping it with an AOD or possibly a 5Spd. manual from a mid '90's 3.8L Mustang . The bell housing should match the block although I'm not sure if the AOD convertor will match up with my flexplate. The other questions are:is the overall length of the AOD or 5 spd. different than the C5 (meaning possibly altering the driveshaft), will I need to change the yoke on my driveshaft, and hook-up of the cooler lines to the AOD. I know with the 5spd. I would need to put in a flywheel, clutch pedals, and see it shifter would line up with the existing cut out on the transmission hump. Has anyone attempted swapping a C5? Am I better off just sticking another C5 in it?
505danielm is offline   Reply With Quote
Old 12-29-2008, 07:39 PM   #2
hottcobra's Avatar
Re: swapping a C5
well if you swap to an AOD you will run into different elec. trans. controls. If you swap to a five speed. the shifter location will be the same, but you may need a new drive shaft.
Old 01-05-2009, 12:28 PM   #3
Re: swapping a C5
I'd recommend sticking with the C5, you'd need less new additions than if you decided to an AOD
Mustang2010 is offline   Reply With Quote
swapping auto to manual fabzmccraw 1979-1995 Mustang GT 3 07-03-2009 05:08 PM
Help! Swapping a 2004 4.6 into 1996 HELP! fast8750 1996-2004 Mustang GT 0 07-03-2009 04:55 PM
swapping an 8.8 diff to a 7.5 rearend??? twin9mils 1979-1995 Mustang GT 6 03-26-2009 10:26 AM
swapping the rear from the 90 into the 64? fast64 Classic Mustangs 8 04-27-2006 10:13 PM
Swapping brakes Rellik Pre-2005 V6 Mustang 11 10-16-2003 07:06 PM
04:27 AM
