Lowering/Raising question - Mustang Evolution
Old 08-11-2004, 11:45 AM   #1
I plan on getting some new tires on the rear. Im going to have 16's all around (No chrome) and the rear tires are going to have bigger walls than the front two tires, and wider. I was wondering when i do this, it is better if i drop the front of the car or raise the back end of the car. And if i do raise the back, what are the springs called? Raising springs perhaps?
Exit_In_Red is offline   Reply With Quote
Old 08-11-2004, 12:26 PM   #2
Danger Dude's Avatar
It is better to lower the front than raise the back. Your car in the back is already high enough. If you did raise the back you would use spring spacers or Air shocks
Here is a tire calculator to help with tire height decisions http://www.miata.net/garage/tirecalc.html
Old 08-11-2004, 12:28 PM   #3
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
I dont know if you would even want to lower the front, depending on tire size i cant see any reason to lower or raise at all.
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 08-11-2004, 12:36 PM   #4
Well if he wante the dragster look he might
Old 08-11-2004, 02:56 PM   #5
97Stallion's Avatar
Why don't you just lower it all together. Lowering you car changes the center of gravity which gives you a better handling car. Also it's better to lower the car all together so that you don't move the center of gravity too far forward. If you have it too far forward, you're weight distrabution well be worse and your rear tires won't have as much weight on them and therefore you'd be getting worse traction and have a higher probability of spinning out, or worse if you drive the car in the snow, you won't be moving long. If you want more of a dragster look, I would go with 245/45ZR17's in the front and 275/40ZR17's in the rear. Your rear tires will be about an inch wider and will give better traction.
--- Note moving to suspension
Living one day at a time!
Old 08-11-2004, 02:59 PM   #6
KrazyPony's Avatar
I cant qwite understand 1 thing here...why 16's? 17 or 18's you hear of everyday, but not 16's?
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 08-11-2004, 03:35 PM   #7
I heard, the bigger the rims, the slower your car. And yes, i am going for a dragster look. Im not really worried about handling, since i dont race around curbs or anything. I live in california, so i dont have to worry about the snow problem. So, i think i'll lower the front. Now that Danger Dude said it, the back is high enough. What other tire sizes do you guys recommend for the rear tires? Thanks for the responses..
Old 08-11-2004, 03:44 PM   #8
Falcon's Avatar
that tire size is about right for a 17 inch rim, a bigger rim will slow you down yes, but i dont think it will slow you down enough for you to acctually notice it doing normal driving.
-Derek
1999 Trans Am WS6
Old 08-11-2004, 04:32 PM   #9
I liek gramer
WhiteStang99's Avatar
I can notice it, I went from stock to 17x9s. It's not bad, but it is noticable. But my car handles oh so much better.
Old 08-11-2004, 10:15 PM   #10
01mineralgrey6's Avatar
Id say if you were going for a drag look, get some weld drag wheels? skinnies up front and wide tires in the rear? i think there 15s, i know Tire had them on his stang and it looked good:yup:
-Tony
'99 cobra 'vert
Lowering?? Gt.Vert 1996-2004 Mustang GT 9 10-12-2009 07:12 AM
question about 02-04 gt lowering springs th3famous1 1996-2004 Mustang GT 11 11-15-2008 12:28 PM
lowering question white 98 gt 1996-2004 Mustang GT 4 08-15-2008 08:34 PM
Lowering car question leo95 1979-1995 Mustang GT 9 11-11-2004 03:00 AM
raising the spedometer charkelly9 Pre-2005 V6 Mustang 21 09-06-2004 05:25 PM
04:01 AM
