notched cross pin - Mustang Evolution
Old 01-01-2009, 12:09 PM   #1
notched cross pin
I've been hearing that after a gear install, there is some grinding and whining when on the road.
Is it worth it to buy an aftermarket notched cross pin when installing taller gears? I'm talking 4.10s since I'm an auto. Its supposed to make the installation and transition easier.
Old 01-02-2009, 07:25 AM   #2
1234's Avatar
Re: notched cross pin
They only grind and whine if they are installed wrong. You need to find a shop or person who knows about gears to do the install.
Old 01-02-2009, 10:17 AM   #3
Scut95's Avatar
The whining means that the backlash isn't set correctly. It should be between 8-10 thousandths. The gears should be quiet or quieter than stock.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 01-05-2009, 05:43 PM   #4
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I got a set of gears from Midwest mustang installed in an 8.8" rear end and I didn't realize in time that they never set the lash at all, which I had paid them to do. About 6 mo. after I got the axle into the car a buddy heard it and told me he thought it was bad gear lash or pinion depth. I felt pretty stupid but I took it to a local tranny shop and he fixed it Turns out they never set the pinion depth in the first place. I have the uncompressed crush sleeve in my glove box. Cost me another $300 and they still whine a little because after the 1500 miles I put on the car it set up an abnormal wear pattern. Get that fixed ASAP.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-05-2009, 05:48 PM   #5
hottcobra's Avatar
all the stock parts will work fine up to 5:56 gears. anytime you hear a noise it's from the ring-n-pinion. via. wrong backlash, pinion depth, or pinion preload.
Old 01-05-2009, 05:49 PM   #6
hottcobra's Avatar
if your gonna try to do it yourself I can wright up a detailed how to for you
Old 01-05-2009, 05:57 PM   #7
If you do that, you should come over here and do it on the 8.8 I have in the back yard and get pics of the write up at the same time. I don't have gears for it, but we could tear it down and put it back together.
Old 01-05-2009, 06:27 PM   #8
hottcobra's Avatar
we can do that
Old 01-05-2009, 06:31 PM   #9
hottcobra's Avatar
I guess we will have to get Gabe over and have a class
Old 01-05-2009, 07:00 PM   #10
You know, I'd love to know how to do that, but I don't think I'd try to learn on my car. lol Wish I could though, I could use my friends lift and save on labor!
easy way to take of pin stripe? blackonblack Mustang Audio & Video 7 05-02-2010 10:07 AM
Why did the chicken cross the road? hottcobra The Bar 9 10-27-2009 01:23 AM
You could of heard a pin drop sonic04edge The Bar 8 08-20-2008 10:43 PM
11:36 PM
