my stang... - Mustang Evolution
Old 08-13-2004, 07:11 PM   #1
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
my stang...
seems to be racking up some wear and tear i've been noticing a squeaking clutch, intensifying shaking or jerking (back and forth) in the chassis as i accelerate (like the tranny is not quite catching, or not cycling fast enough) squeaking brakes... it also seems like it may be making less HP... i've checked the oil, she doesn't appear to burn or lose any at all...
i'm thinking i should change the spark plugs, it hasn't been done since i bought the car... i know my oil is about due to be changed (i use synthetic)... maybe she just needs an all around tune up?
i dunno, give me some thoughts... my stang is a 97 5 speed, completely stock, been wrecked twice (once by me, once by previous owner) 85,5XX miles... i'm careful not to push her above 3K
thanks in advance
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 08-13-2004, 07:18 PM   #2
fast64's Avatar
well, squeaking brakes means its time for a brake job, lol. I say take one saturdayor something and give her a all around tune up.
GO BRAVES
Old 08-13-2004, 07:21 PM   #3
Danger Dude's Avatar
A good tune up including Plugs, Plug wires (If they are stock) Air filter, Oil change, check or replace the PVC valve, Check the battery for fluid, might want to get the brake fluid change (Brake fluid absorbs 5% to 10% water moisture every year and causes spongy brakes) check the Power steering fluid, also a good time to change tranny fluid and filter if you have a Auto.
Old 08-13-2004, 07:24 PM   #4
dark's Avatar
corey, what price range would all that be in? i have 100$ to spare until next week... then i'll have about 150 more after i pay my bills
get at me on aim if you want to discuss this, it's faster than hovering in one spot lol
Old 08-13-2004, 07:40 PM   #5
Probably $150 or so
Autolite or Motorcraft Plugs $8.00 for a set of 6
MSD Plug wires $70
Brake fluid change at a shop $40
New PVC valve if needed $4.00
Air Filter $8.00 to $40 depending on the type
Battery fluid if low get filtered or distilled water
Change radiator fluid if needed
Old 08-13-2004, 07:50 PM   #6
97Stallion's Avatar
When I changed my plugs and wires, wow what a difference that made.
Living one day at a time!
Old 08-14-2004, 11:03 AM   #7
dark's Avatar
aight, i'll do that next weekend
Old 08-20-2004, 05:24 AM   #8
dark's Avatar
now i just need to know the process for changing plug wires
lol i've never done it before
Old 08-20-2004, 05:31 AM   #9
Change one at a time so you know where it goes back to. Take one wire loose form the plug and then take it off the coil pack. Take the plug wire and match it to the properly lengthed wire that comes in the new plug wire kit and then reinstall.
Old 08-20-2004, 01:38 PM   #10
dark's Avatar
what tools will i need? i know i'll need a ratchet to get the plugs out
Old 08-20-2004, 02:26 PM   #11
Monkey's Avatar
plug wires you just need to pull the boots off the spark plugs and the other end. spark plugs, you need a spark plug socket with an extension and a socket wrench.
Old 08-20-2004, 02:31 PM   #12
97Stallion's Avatar
Never use a rachet when removing torque from a bolt or spark plug. Use a 3/8" breaker bar. Also you're going to need a 5/8" deep well spark plug remover socket, some 3/8" drive extensions (perferably have them about 6" long), and you'll need a 3/8" drive swivel.
V6 Stang ponyboy1995 Regional Mustang Discussion 2 08-24-2006 03:31 PM
Attn Stang Auto stang owners (quick question) Bane- The Bar 7 09-09-2004 11:53 AM
my stang lowflyn Mustang Audio & Video 20 08-22-2003 08:33 PM
10:26 PM
