performance clutches - Mustang Evolution
Old 08-13-2004, 10:59 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
im new to 5 spd performance and i was just wondering what gains i will see with i new clutch, i dont mean hp but what benefits will i get out of a performance clutch? and will i see any benefits on a mostly stock car?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 08-13-2004, 11:46 PM   #2
SquirrelNutz154's Avatar
Send a message via AIM to SquirrelNutz154
Many better upgrades to make. Its a good one if you're pushing a lot of HP or if youre clutch is slipping, but on a fairly new car with a decent transmission, I'd spend the money on something else.
Sponsored by Ignited Performance and Classic Design Concepts
Cardomain Site
SquirrelNutz154 is offline   Reply With Quote
Old 08-14-2004, 12:08 AM   #3
01mineralgrey6's Avatar
Basically you can get a beefeir clutch for more clamping force to the flywheel.usually requires more effort too.... I wouldn't be worried about the clutch till you need to replace it but i would say get a short throw shifter, clutch quadrant, etc. I think Horse has a steeda quadrent hes trying to sell.
-Tony
'99 cobra 'vert
Old 08-14-2004, 11:23 AM   #4
the ability to NOT be able to feather the clutch (alot of spin) lol if your clutch is not slipping then you should not worry about it, if you get a really stiff clutch you wont be able to feather it to take off so you will wind up "dumping it" and having alot more spin/alot less control over the clutch as it engages.
Old 08-14-2004, 09:27 PM   #5
three stupid questions im sure. 1) what is a clutch quadrant? 2) what is a throw bearing? and three what good does this do?
QUOTE=SpectorV]the ability to NOT be able to feather the clutch (alot of spin) lol if your clutch is not slipping then you should not worry about it, if you get a really stiff clutch you wont be able to feather it to take off so you will wind up "dumping it" and having alot more spin/alot less control over the clutch as it engages.[/QUOTE]
Delta Sigma Phi
www.DeltaArmsCo.com
Old 08-15-2004, 07:20 AM   #6
The clutch quadrant is more for a heavy duty clutch, The stock ones are plastic, and after a while they bend causing inconsistant clutch engagement/ missed shifts. Just a little insurance if you get a heavy duty clutch or like to shift hard.
The throw out bearing pushess on the "fingers" of the pressure plate causing the clutch to dis-engage.
-Tony
'99 cobra 'vert
Old 08-15-2004, 11:46 AM   #7
well you know how on your stock clutch you can kind of ride on it as it engages you dont have to just let it out all at once, you have a kind of 2 inch area when letting in/out on the clutch petal that the clutch is not engaged/not engaged with an aftermarket you dont have that much area its very stiff and the clutch is usually engaged or not, no room to play really lol
Old 08-15-2004, 03:50 PM   #8
ok thanks guys. when i have driven 5 spd stangs i find having the ability to feather the clutch is not only fun but its like a safety thing when your in the show. well thanks for the help
Delta Sigma Phi
www.DeltaArmsCo.com
Old 08-15-2004, 07:08 PM   #9
is the upr triple pick up quadrant and cable and fire wall adjuster good
Old 08-16-2004, 04:51 PM   #10
i need that to be answered quik so i can install my spec stage two clutch
Old 08-16-2004, 10:44 PM   #11
anybody
Old 08-17-2004, 05:14 AM   #12
I guess Most of the people i know get the Steeda stuff.
-Tony
'99 cobra 'vert
Old 08-17-2004, 12:15 PM   #13
any links to the steeda one with cable fire wall adjuster and quadrant
Old 08-17-2004, 01:19 PM   #14
damn straight from steeda its one hundred bucks plus shipping any sites have it cheaper
Old 08-17-2004, 03:45 PM   #15
i think i will just get upr
Old 08-17-2004, 04:53 PM   #16
upr or steeda both do the same job and work just as good, just make sure you get a firewall adjuster to take all the slack out of the petal or flop or what ever you want to call it.
if the petal is to high you can get an adjuster kit from maximum motorsports.com to fix it but you definatly want to take all the slack out of the clutch petal so its frim at the top and has half an inch of travel before the cltuch starts to slip/go into neutral.
Old 08-23-2004, 05:55 PM   #17
well i found thet straight from upr its pretty cheap so now i will get the quadrant adjuster and cable straight from them but one question there is an option for ten bucks more to have the premium cable is it worth it or is it just another way of getting more money out of my pocket
Old 08-23-2004, 07:57 PM   #18
any one
Old 08-24-2004, 07:04 PM   #19
n e 1
Old 08-27-2004, 05:43 PM   #20
yes on the premium cable or no ?
Old 08-29-2004, 01:22 PM   #21
cmon this is the only thing stopping me from putting on my clutch
Old 08-29-2004, 01:46 PM   #22
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
to shut you up...no ...seriously though its probably not needed if its an option, unless you want the supposedly premium cable then get it, its only ten bucks. ive never heard of such a premium cable but maybe someone else knows more???spector???
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
8.8 tracklok clutches ringpinion.biz Mustang Parts for Sale and Wanted 1 08-03-2006 01:45 PM
? about clutches HotRod.riguez Pre-2005 V6 Mustang 3 07-17-2006 06:45 PM
Clutches! FloMasta24 Pre-2005 V6 Mustang 10 08-14-2004 01:39 PM
clutches STEVE Pre-2005 V6 Mustang 23 07-04-2004 08:52 AM
Why Mustang clutches > Firebird Clutches Rellik The Bar 4 03-03-2004 11:48 PM
02:14 PM
