Im about to dump some $$$$$$$ - Mustang Evolution
Old 05-04-2003, 02:05 PM   #1
Send a message via Yahoo to SexyStang
*Next week I have to change transmission fluid and filter.
*PCV Valve
*Spark Plugs
*Fuel Filter
*Engin oil(high milage)and filter
*Rear Brake Pads
*Turn Roters
I hate spending $$ on maintenance. But I save big bucks doing it at home myself.......If I dont know how to do it. I read my big ford mustang book. I follow the directions like a recipe and everything always works out. lol
SexyStang is offline   Reply With Quote
Old 05-04-2003, 03:31 PM   #2
Send a message via ICQ to Scorpion99 Send a message via AIM to Scorpion99
haynes manual helps now and again too :p
good luck, just don't end up with a couple extra bolts for something
Scorp
Scorpion99 is offline   Reply With Quote
Old 05-04-2003, 05:04 PM   #3
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Re: Im about to dump some $$$$$$$
*PCV Valve
*Spark Plugs
*Fuel Filter
*Rear Brake Pads
*Turn Roters
Kristl,
Most of that stuff is pretty inexpensive, and easy to do.
I would actually recommecd taking it to a place to get the tranny fluid and filter changed. (just because it can be a #####)
*The PCV valve is very inexpensive and easy to put on. They are 2 bucks at any auto store.
*Spark plugs are pretty inexpensive as well. Depending on the application you got (nitrous, blower, ect.) You would want them gapped differently or a different metal. For a stock application i would recomend Motorcraft Double Platinums. They will last a good 100k miles. They are about 4-6 bucks each. Copper is like 99 cents each, but they last only like 20-30k miles.
*Fuel filter is about $10 bucks, but it also requires a cheap tool to remove the lines from the filter casing. Very easy to do as well.
*Engine oil, any kind of synthectic oil will do fine.
And as for the brakes. By your self the rotors... I would recommend a nice set of powerslots. You will get raped in charges taking it somewhere else when they buy rotors and brakes. Ford estimated me 600 for rotors... When power slots are $200.
Rellik is offline   Reply With Quote
Old 05-04-2003, 08:36 PM   #4
Thank you for all the tips. I have the $2.35 tool to take the fuel filter off. Ive changed it onec before. And at that time I didnt know about the too. I found out the hard way. And here is a hint for everyone who has never done it. MOVE! The gas squirts out. Thats right. Right in the face. lol
Im just turning the rotors and Im going w/ ceramic pads.
And Andrew, I thought it was normal to have a few extra parts or not enough. lol
kristi
« - | Brakes....... »
*sigh* Mach 460 took a dump jimmy_beaner Mustang Audio & Video 0 05-20-2007 01:05 PM
Water pump took a dump KyleUSAF Pre-2005 V6 Mustang 16 01-25-2006 01:35 PM
dump the clutch before launch? good advise? jones4stangs Pre-2005 V6 Mustang 2 10-25-2005 11:18 PM
Taking a dump at work, which one are you? Rellik The Bar 6 10-27-2003 09:06 AM
03:57 PM
