373 or 410 void factory warranty?? - Mustang Evolution
Old 08-20-2004, 03:55 AM   #1
gforces69's Avatar
newbie here! does anybody know if i swap out my ring and pinon w/t-lock will it void my warranty? thanks for you help....04 v6 mustang 4000 miles!
gforces69 is offline   Reply With Quote
Old 08-20-2004, 04:43 AM   #2
Danger Dude's Avatar
It would void the warranty most likely on the rear end assembly. But they would have to know you had changed it. There is really no wayto know you changed it unless looked inside it. So unless there was a problem with the rear end they would never know and so I would not really worry about it.
Old 08-20-2004, 05:39 AM   #3
97Stallion's Avatar
Ya, and don't go blabbing your mouth either. If they ask, don't lie about it. You could play stupid though. Either way, they'll never know unless you tell them, or unless they pull the rear-end cover off.
Living one day at a time!
Old 08-20-2004, 07:53 AM   #4
Think Bill Clinton.Don't ask,don't tell.I'm soon changing to 4.10 myself.
Ghostbuster is offline   Reply With Quote
Old 08-20-2004, 08:13 AM   #5
they wouldnt be likly to know you had gears installed unless you had a problem with the rear end and asked them to check it out/fix it. It will void the whole rear end assembly so any future issues would be your problem. you should just buy an 8.8 for 850 or less (including shipping) and just bolt it up and keep your 7.5 stock for a back up or if you ever just need to put it back in for some reason, 850 vs 600 or more for just 7.5 gears its not much worse to just upgrade to an 8.8 and you will thank your self later that you did.
Old 08-20-2004, 09:57 AM   #6
Ponycarman's Avatar
The only way any manufacturer can void a warranty is if they can prove the mod caused the problem. Otherwise they cannot void a warranty. Obviously there is no factory warranty on the modded part since that is not factory.
The Magnusson-Moss warranty act is the legal basis for what can and cannot be done in regards to mods and warranties. You can thank Magnusson superchargers for it.
http://www.ftc.gov/bcp/conline/pubs/...s/warranty.htm
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 08-20-2004, 10:03 AM   #7
Steve
Well if you put gears in and the axle fails or a drive shaft the warranty is void if they find out the gears were changed. Most dealers will gamble that you wont get anywhere if you complain anyway
Old 08-25-2004, 12:08 PM   #8
Ponycarman's Avatar
They are required by law to prove it, you are not required to prove it didn't. If you take them to court the costs are likely to exceed the repairs anyway. It's up to you though.
Steve
1996 Mustang
1965 Barracuda
Old 09-02-2004, 09:31 AM   #9
Where can I find pricing for 8.8 rear ends (new or used) online?
I see prices for 7.5 gears and diffs everywhere but not for 8.8 rear ends. The cost of diff+gears+install is expensive enough, if it cost a little more for a more robust rear end it would be worth it.
Thanks
Jason
akira01 is offline   Reply With Quote
Old 09-02-2004, 11:11 AM   #10
where can i buy a whole 8.8 rear end brand new with the gears if my choice and t-lok. i want everything to be brandnew
Old 10-12-2004, 09:53 PM   #11
fastmustangs1's Avatar
Thumbs up
It probably will void your warranty any time you modify the drivetrain it has the potential to brake something else according to the factory. It is expensive to have done but it is well worth the effort.
Matt 2001 moded V6.
fastmustangs1 is offline   Reply With Quote
8.8 rear end 373 gears seeya 1996-2004 Mustang GT 3 12-04-2007 07:21 AM
410 gears? 98StangGT 1996-2004 Mustang GT 7 02-05-2007 06:51 PM
FS: 8.8 410 ring & pinion new slvr2000stang Mustang Parts for Sale and Wanted 1 01-08-2007 06:30 PM
does cold air intake void the warranty? kyl3 The Bar 16 10-08-2004 01:02 PM
410 gear speedo question Freds3.8 Pre-2005 V6 Mustang 23 07-21-2003 02:07 PM
08:46 AM
