spray question - Mustang Evolution
Old 08-22-2004, 11:17 AM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
spray question
i just wanted to know, when is it safe to spray on a 5 spd manual? i know u shouldnt spray in an auto until u hit second gear but how about a 5 spd?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 08-22-2004, 11:18 AM   #2
you could do it
Old 08-22-2004, 12:23 PM   #3
i think anything above 2500 rpm in any gear is pretty safe. not too sure so back me up guys.
2000 5spd black/ cai w/ k&n, dual exhuast w/ H-pipe
stangracer is offline   Reply With Quote
Old 08-22-2004, 12:48 PM   #4
Don't spray below 2500 RPM. Personally I spray only over 3K to prevent pooling in the intake. Don't want to detonate that fuel and N20 in the intake.
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 08-22-2004, 12:58 PM   #5
Dom
Dom's Avatar
Send a message via AIM to Dom
You spray about 3K so the engine wouldn't have to work so hard and also so it won't pool. Never spray off the line and you feel it more when you spray in a low gear. (2nd-ish)
Monkey knows alot about nitrous and so does Zim. Catch them and ask any more questions you have.
Old 08-22-2004, 02:10 PM   #6
Danger Dude's Avatar
The best way to control the sprray on a Manual is with a MSD RPM activated Window switch that lets you set what RPM your nitrous will come on and shut off at. They are not expensive
Old 08-22-2004, 02:18 PM   #7
97Stallion's Avatar
Definately the way to go!!!
Living one day at a time!
Old 08-22-2004, 03:09 PM   #8
Monkey's Avatar
you can spray off the line... I have several times. Granted I had a stall converter that allowed me to rev to 2300rpms before launching and 4.10s in the rear, so getting above 3k was never an issue fast.
anyway, don't spray below 3000 in any gear except first. first the rpms are climbing fast enough to where you can spray at 2500-2750. If you have a manual, get a window switch. That will prevent anything disasterous if you hit the fuel cutoff or rev limiter or shift too slow and lose rpms.
Old 08-24-2004, 10:47 AM   #9
N02 is FUNNNNNNN
Just remember. More is better ....= BOOM.
Most kits send the same amount of N02 in for the entire burst (shot). You are increasing cylinder preasure enough to make an extra 75-100 hp at 5k rpms, so.....at 2k rpms, cylinder preasure is going to be off the charts. Dont expect headgaskets to last long if you do that on a regular basis.
Someone mentioned not spraying in 1st gear. I dont understand that, unless the goal in that is to reduce wheel spin. If you are worried about that, get some drag radials, run them at 12 psi when you are at the track. I pulled 1.6 60' times with them on my old car.
oh1coupe is offline   Reply With Quote
Nitrous Express Intercooler Spray kit(new) 99MustangGTman Mustang Parts for Sale and Wanted 19 07-30-2008 01:01 PM
NX intercooler spray kit+accesories!! 99MustangGTman Mustang Parts for Sale and Wanted 9 07-16-2008 07:42 PM
springs spray rubber prepped jimmy_beaner Pictures and Videos 24 05-21-2008 05:36 PM
contemplating the spray again Kyle Pre-2005 V6 Mustang 34 02-22-2008 08:17 AM
10:08 AM
