70mm V6 throttle body help - Mustang Evolution
Old 08-22-2004, 09:58 PM   #1
i have heard that it needs some sanding in fitting for a 2002? if this is true, is it worth the investment?
skylar1926 is offline   Reply With Quote
Old 08-22-2004, 10:50 PM   #2
What mods do you currently have? Unless you have a stroker or power adder 70mm is overkill
Old 08-23-2004, 08:49 AM   #3
slvr2000stang's Avatar
From what I have heard, it is not a direct bolt up. Modifications need to be made to make it work correctly.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-27-2004, 08:58 AM   #4
i have CAI, Duals, and im about to install underdrive pulleys....sooner or later i was thinking of throwin on a charger of some sort...after some other mods of course..its all in the future...just thought id do some researching
Old 08-27-2004, 09:44 AM   #5
In your current state it will most likely cause a loss of hp.
2000 Vert 4R70W
Old 08-28-2004, 05:17 PM   #6
RGR
Send a message via AIM to RGR
Porting the intakes will do more for you,
and the 70 takes extensive mods. I did
one for Capt. Kirk (silver2000) and he got
post removal and crossover tube work to
boot. He is gonna run an SC with it. But
to add to what these guys said, I would
use it for high RPM 3.8's, power adder
setups and strokers. Most street 3.8's
are fine with a stocker that is modded.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 09-01-2004, 05:44 PM   #7
what about headers...are they worth the addition for power
Old 09-01-2004, 05:48 PM   #8
HELL Yes!~
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 09-01-2004, 05:49 PM   #9
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
on a v6 with very few mods your not gonna see many gains from them
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 09-01-2004, 06:18 PM   #10
RGR
With a cam and porting, I would say YES.
For minor mods, (just boltons) and modest goals, maybe not.
Depends on your budget, and headers are not
a good dollar/HP ratio on near stock cars.
But the LT's and a cam and porting is a great combo!
Old 09-01-2004, 06:45 PM   #11
97Stallion's Avatar
I completely agree, you'll need a huge air sucking engine to require a 70mm TB.
Living one day at a time!
Old 09-01-2004, 07:23 PM   #12
RGR.
What do you think about LT's with my new setup?
Worth it pre-blower?
2000 Vert 4R70W
Old 09-01-2004, 09:00 PM   #13
Danger Dude's Avatar
Like Robert said No cam no Lt's. Dont waste money chasing advertiser claims. Most claims are based on GT's and they use them for V6's and that is a scam!!!
Old 09-02-2004, 09:49 AM   #14
RGR
Originally Posted by slvr2000stang
RGR.
Yes, since you are getting the cam, porting, and all that.
But if you were staying NA the cam and or header requirements
would be change, you can do it pre-blower but I would say
you stand to gain minimally in teh pre-blower setup, your cam
has extra Exhaust duration (for the blower) and that plus LT's
will over-scavenge the exhaust a bit, but at this level it may be
a very minimal power (imperceptible) power loss, but perhaps
a noticeable mileage gain!
Old 09-02-2004, 10:18 AM   #15
Thanks..
That is what I figured but thought I would ask.
2000 Vert 4R70W
Old 09-02-2004, 12:58 PM   #16
why does the newer model stangs only use the harmonic balancer rather than the entire pulley set the 98s and below use
Old 09-02-2004, 01:09 PM   #17
Starting in 99 the stock pulley & harmonic balancer became a one piece unit.
So to go to an under drive pulley you have to get a replacement balancer and the new pulley. Pre 99 you just need the new pulley.
2000 Vert 4R70W
Old 09-02-2004, 05:03 PM   #18
when i get my heads/cam/intake swaped i plan to go with long tubes and high flow cats and run it out to tips but till then or till you have motor work or a blower heads are worthless.
Old 09-02-2004, 07:35 PM   #19
ive looked and all i can find is the harmonic balancer...where can i find the pulley?
Old 09-02-2004, 07:54 PM   #20
http://www.aspracing.com/intro.htm
2000 Vert 4R70W
Old 09-02-2004, 08:02 PM   #21
thanks...so the damper pulley and the harmonic ballancer should do the trick
Old 09-02-2004, 08:07 PM   #22
When you order for a 99+ you get a new harmonic dampner & the Underdrive pulley in the kit.
2000 Vert 4R70W
Old 09-02-2004, 08:14 PM   #23
Does That Website Offer The Belt To Go With The New System
2002 3.8L DUAL FLOWS WITH CAI....MORE ON THE WAY....
Old 09-02-2004, 08:17 PM   #24
They have the size you need and can get at any auto parts store.
I ordered mine from http://www.rpm-mustangs.com/ and ordered the belt too.
2000 Vert 4R70W
BBK 70mm Throttle Body install rstewart Pre-2005 V6 Mustang 11 11-18-2008 12:16 PM
» Members Mustangs
13savage6
earl
94sccoupe
Add your Mustang
01:36 AM
