Need some engine advice B4 I go to the races - Mustang Evolution
Old 07-15-2003, 01:06 PM   #1
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I'm borderline in need of an oil change. I'm at 2500, and I usually change it between 2700 and 3000. I'm going to the drag track this weekend. Should I change my oil,, or should I keep the oil that my engine is used to for better performance? I'm undecided. Any advice?
Rellik is offline   Reply With Quote
Old 07-15-2003, 01:19 PM   #2
Danger Dude's Avatar
OMG the oil question hahahahaahha Just go the way it is. Theoretically the thinner used regular oil (older oil that looses viscosity) will cause less drag on the engine.
Corey
Old 07-15-2003, 01:24 PM   #3
First time at the track. And I used the search button but didnt find anything .
If it makes any difference, I just had my tires rotated and re-ballanced. I'm sure that was a wise Idea... right?
Old 07-15-2003, 01:33 PM   #4
Yes to make sure your tires are balanced so they track true and wwill actually help your time.
Corey
Old 07-15-2003, 01:35 PM   #5
Any reccomendations on tire pressure?
Old 07-15-2003, 01:46 PM   #6
what tires are you running
Old 07-15-2003, 01:46 PM   #7
Old 07-15-2003, 01:51 PM   #8
Ruadhugger 225/55R16
Old 07-15-2003, 03:23 PM   #9
What the hell is a Ruadhugger !!!!!!!!!!!hahahahahahahahha
do the tires spin real bad in the rain with a moderate launch in the rain. If the tires have excellant traction Leave the air at recommended pressure. if tem are easy to break loose drop 5 lbs of pressure and try to get them to nreak loose
Corey
Old 07-15-2003, 03:29 PM   #10
I can still launch in the rain without spinning too terribly bad. If I dump the clutch, Of course I can spin them. It's all depending on how much water is on the ground.
Roadhugger Rage tires are just a brand name. As long as they keep my car rolling, I dont care.
Next question:
Should I avoid the waterbox? Or go through it and just light them up for a second?
Old 07-15-2003, 06:04 PM   #11
if you have really good traction in wet weather no need to avoid the water box.
as far as the brand I was not goofing on them you said ""RUADHUGGERS"" not road huggers
Corey
Old 07-15-2003, 06:19 PM   #12
tire's Avatar
Send a message via AIM to tire
Re: Need some engine advice B4 I go to the races
uh... dude it's ok, run your car. you can go more than 5k miles without real damage... you conventional or synthetic though?
synth. can last longer but still needs to be changed almost as often.
tire is offline   Reply With Quote
Old 07-15-2003, 06:21 PM   #13
tire's Avatar
Next question:
skip the waterbox anyways, don't want water dripping fromt he wheel wells onto your tires. light up your tires for a second to get the crap off of them. lower psi to 28psi and lower 2psi at a time until you feel you have the best grip. don't worry about reaction time, jsut try to launch well first.
Old 07-15-2003, 06:23 PM   #14
tire's Avatar
what brand?
Old 07-15-2003, 07:17 PM   #15
Cool, thanks guys. I've been practicing launching for about the last 2 months... It's an art more than a science really IMO.
If there are any other little tricks you uys know.. I would be more than eager to hear them.
V6, Road Hugger is the brand. IF they're jsut an offshoot from some other larger company, I dont know.
Old 07-16-2003, 01:15 AM   #16
This will be my first time at the track as well! 8) Finally a leagal race. I'm just going to go and run it with a bunch of fellow V6s and have a good time. Rellik, i wouldnt really worry about it that much. Just have a good time.
2003 Black Cobra Coupe
Current Mods: Flowmaster Cat-Back & Tinted Windows
Future Mods: 18x10.5 HRE's, S-281 Spoiler & Side Scoops, & KB Blowzilla
Red, White, and Blue --- The Colors that Hold True
Previous Car: '01 Silver Vert V6 with MAC Cat-Back Dual Exhaust, CAI, 17x9 Chrome Cobra Rs, Billet Grill with Pony Insert
What Ford Needs to make the Next Gen SVT Cobra look like!
http://www.mustangmods.com/data/1251...avatar_gmg.jpg
Stang01 is offline   Reply With Quote
Old 07-16-2003, 02:09 AM   #17
tire's Avatar
just do what i said about avoiding the waterbox, burn for a second to get tires free of crap and lower to 28psi or less. gut the car of crap and make sure you were closed toed shoes and pants or you wont' be able to race for safety reasons. only a 1/4 tank of gas in tank.
also let your car sit for at least 30 minutes between runs. i gained nearly 4 mph in the 1/8th trap wise between hot lapping my car and icing my intake so that it was cold... 68--> almost 72mph!
-austin
Old 07-16-2003, 08:58 AM   #18
I guess I'll be bringing a few bags of ice... seeing how racing starts at 4 pm . When it's still pretty warm outside
I'll avoid the waterbox and drop the PSI.
And dont worry, I've practically memorized the rules that Cal Speedway put out for racing on their tracks. Jeans, closed shoes, T-shirt. The rules are posted in the Cal speedway thread in The Cali section.
Thanks for all the help guys.
Stang01, you do realize that there are a lot of other types of cars going to be there... right?
Old 07-16-2003, 10:47 AM   #19
tire's Avatar
oh and make sure on the way over there that you turn your A/C OFF. don't want to drip water from the condenser on the track and look like a foo' (like i did my first time! )
Old 07-16-2003, 10:55 AM   #20
You sure? I'll be there before noon, and tech inspection starts at 2, and racing starts at 4. You sure it wont all go away by 4?
I usually dont run with the A/C anyway. I'll just leave it off anyway.
Old 07-16-2003, 11:54 AM   #21
Send a message via AIM to TORCH_RED
yeah, you'll be just fine....
TORCH_RED is offline   Reply With Quote
Old 07-16-2003, 04:20 PM   #22
Rellik--- Of course i do. I've been to Cal Speedway before. They have an Import division Boring!!! Then they have a domestic division which is awesome 8)
Old 07-16-2003, 05:55 PM   #23
Sweet!! I juess there is amuch better chance of all the 6'ers racing together then
Old 07-17-2003, 04:51 AM   #24
Torch Red--- Where did you get that Icon???? Its awesome!!!!
Old 07-17-2003, 06:16 AM   #25
well, first off i got it from someone of supraforums.com....then dark e from 3.8mustang blew it up for me....and waaa laaaa!
need engine advice upton7 General Car Discussion 8 05-04-2010 06:26 PM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need advice for 04 3.9 engine MusTangsRunWild Pre-2005 V6 Mustang 2 04-24-2009 12:34 PM
Need engine build(er) advice. PureVenom 1979-1995 Mustang GT 22 09-17-2005 11:37 AM
engine advice tealstangman Pre-2005 V6 Mustang 6 01-19-2004 04:35 PM
11:12 PM
