raising the spedometer - Mustang Evolution
Old 08-26-2004, 09:45 PM   #1
Send a message via AIM to charkelly9
Hey guys im new to this so bare with me. My 03' v6 vert's spedometer only goes to 120 is there any way i could get a different gauge that allows my spedometer to go to 150 ( like the gt's) with the help of a fordchip. If this is all just ridiculus then just tell me. Would that just blow or destroy my engine?
charkelly9 is offline   Reply With Quote
Old 08-26-2004, 09:54 PM   #2
01mineralgrey6's Avatar
You could put a GT speedo cluster in there, and have the computer programmed for that, but your factory speed limiter is about 118-120 MPH, so you would probably want that removed/ rasied also. are you just wanting this for looks? or do you intend on 120+ speeds
-Tony
'99 cobra 'vert
Old 08-26-2004, 09:56 PM   #3
i donno. would 130 mph blow my engine?
Old 08-26-2004, 09:57 PM   #4
looks is a big part of it thou. and like if its not possible to even get up to 130 then forget it b/c ive seen how long it takes to change gauges
Old 08-26-2004, 10:02 PM   #5
Im sure it would do 130 with a chip. I don't know. I've hit the speed limiter in mine, and that was plenty fast for me(for now)
-Tony
'99 cobra 'vert
Old 08-26-2004, 10:03 PM   #6
its very easy to change the gauge but fixing the computer is the problem
Old 08-26-2004, 10:09 PM   #7
what do you mean the problem... i thought all you needed was a tuned chip
are the gauges that easy.. i cause then i might do it just for looks
Old 08-26-2004, 10:14 PM   #8
Zim
You want to **** me?
Zim's Avatar
gauges that go to 150 have different redlines than our lil sixers... its not worth gettin a new guage, if youre above 120mph you shouldnt be lookin at your guages anyway lol
I like toys
Old 08-26-2004, 10:17 PM   #9
Forgot the tach was different, and your right...should be watchin the road
-Tony
'99 cobra 'vert
Old 08-26-2004, 10:19 PM   #10
Monkey's Avatar
what year car do you have? if you have a 99+, then you can turn the digital odometer into a digital speedometer by holding on the reset button during start-up (i think thats it. look on www.mustangworld.com)
Old 08-26-2004, 10:42 PM   #11
jimmy_beaner's Avatar
Region: Iowa
my car has a limiter right on the 115 mark... trial and error (luckily no error )... I was curious.... and yeah, I looked, GOD I love straight country highways
Old 08-27-2004, 09:48 AM   #12
97Stallion's Avatar
The 94-98 can use 150 MPH and can have the right tach, but the 99+ are SOL when it comes to this.
Living one day at a time!
Old 08-27-2004, 10:34 AM   #13
well mines a 03' automatic so im parta that SOL group..
Old 08-27-2004, 12:27 PM   #14
Monkey's Avatar
just use the digital speedometer. it will be accurate over 120mph
Old 08-27-2004, 12:35 PM   #15
How do you use the 150mph for 94-98?
Old 08-27-2004, 01:33 PM   #16
97Stallion's Avatar
I WON'T TELLLLLLLLLLL........................
Old 08-27-2004, 01:36 PM   #17
97Stallion's Avatar
Anyways, you need to get a 94-95 speedocluster (the whole thing, not just the face gauges) and then you need to get a green speedo drive gear, and pop that into your tranny. For this you have to actually pull the tranny and remove the tailshaft housing. Remove your yellow 7T gear and replace it with the 8T green gear. That's all.
Old 08-27-2004, 03:18 PM   #18
tried it today in my 02 didnt work
Old 08-27-2004, 04:10 PM   #19
Monkey's Avatar
http://www.mustangworld.com/ourpics/fcar/dtcodes.htm
read that
Old 08-27-2004, 06:42 PM   #20
well having a 150 mph speedo would make 75~ more accurate, the middle point on a guage is usually its most accurate, why people buy 10k tacks so 5-6k is most accurate, if the tach only went to 6k then 3k would be the most accurate point on the tack, even with that its a bad idea to mess with the gauges.... you dont need to go over 120 mph.
Old 09-06-2004, 04:01 PM   #21
I tried it on my '01 V6 manual, and it works! The only problem I have found is that it says that I don't have any oil pressure. Everything else is awesome!
Sharpie is offline   Reply With Quote
Old 09-06-2004, 06:25 PM   #22
wooot it worked
96 GT Spedometer seems to be off sgranitz 1996-2004 Mustang GT 7 05-13-2008 07:53 PM
Lowering/Raising question Exit_In_Red Pre-2005 V6 Mustang 9 08-11-2004 11:15 PM
05:47 AM
