pulley install... yes, i read the sticky - Mustang Evolution
Old 07-15-2003, 04:02 PM   #1
I ordered my pulley and belt today... making plans now for the install.
Other than snapping the bolt, has anyone run across other "gotcha's" that I should be aware of?
Right now, I plan on following the play-by-play as shown on the mirracerros website. Has anyone found any flaws with these instructions?
I assume that the destructions for a 2000 should be basically the same for an '01, right? I know the part is different because, Ford in their infinite wisdom likes to change things mid-production... but is the installation basically the same?
geez... you'd think i've never done this before.... well, it has been about 15 years since i did this last. and that was on a chevy... ahh, the good ol' days. :
Silver '01
ASP 25% UDP
GT Take-off Exhaust
Mac CAI
Powerslot Rotors / Hawk Pads
Steeda Sport Springs
Steeda CC plates
Steeda HD rear sway bar
17x9 Bullets
Nitto 555s (275 rear, 245 front)
ericstanley is offline   Reply With Quote
Old 07-15-2003, 05:50 PM   #2
slvr2000stang's Avatar
Just make sure you have a longer bolt to install the balancer. It's a lifesaver.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-16-2003, 01:41 AM   #3
tire's Avatar
Send a message via AIM to tire
as far as i know it should work on your car, but no promises. what length belt do you have. most run 96" belts but i have a 96.6" belt with no problems.
tire is offline   Reply With Quote
Old 07-16-2003, 05:44 AM   #4
Ken
Ken's Avatar
Region: New Hampshire
Longer bolt is very very important. Also on my AODE I had to wedge a breaker bar into the pulley to keep it from spinning while I cranked on the main bolt that holds it in place.
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 07-16-2003, 11:05 AM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
The 2001's and up are internally balanced, doesn't that mean they don't have the dampener the same as the early 2000's and older?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-16-2003, 02:32 PM   #6
They still have a dampner. It's just neutrally balanced.
2000 Vert 4R70W
Old 07-16-2003, 03:39 PM   #7
Region: Iowa
Gotcha, that's why mine has the raised part and the new ones don't. I thought that raised part WAS the dampener.
Old 07-17-2003, 08:02 PM   #8
It's coming with a 96.8" belt.
Silver '01
ASP 25% UDP
GT Take-off Exhaust
Mac CAI
Steeda CC plates
17x9 Bullets
Old 07-17-2003, 08:03 PM   #9
Great pic's. Thanks for the suggestion!
Silver '01
ASP 25% UDP
GT Take-off Exhaust
Mac CAI
Steeda CC plates
17x9 Bullets
Old 07-21-2003, 10:51 PM   #10
Okay,
So I got it installed yesterday with vitually no problems. After driving to/from work today I opened the hood while it was running just to make sure everything looked okay... not so much. I noticed that the balancer appears to be wabbling quite a bit, although the pulley looks straight.
When I installed it I torqued it down to 115 ft/lbs... before I installed, I compared the new one to the old one and it appears to be the correct version (i.e. the 2001/2000 change). Anyone have any idea what I may have done wrong? I followed the instructions on the mirracerros website...
Help!!!!!
Silver '01
ASP 25% UDP
GT Take-off Exhaust
Mac CAI
Steeda CC plates
17x9 Bullets
Old 07-21-2003, 11:43 PM   #11
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Ken you need a breaker bar.
Rellik is offline   Reply With Quote
Old 07-24-2003, 08:38 AM   #12
someone help this man...
http://www.mustangmods.com/data/1581/sig3.jpg
Check out my car on cardomain!
CAI (99+), 17" 01' GT rims, Hankook hrII tires, interior switch pony, dressed up engine (blue), other numerous appearance mods
Sil\/erSpeed is offline   Reply With Quote
Old 07-24-2003, 09:02 AM   #13
Perhaps the harmonic ballancer as not installed the same way that the original was taken off. It if's off be even a few degrees, it will cause a wobble.
Old 07-24-2003, 02:32 PM   #14
good call...i thought about that, but didnt say anything. BTW, our year does not have that same harmonic balancer does it?
Old 07-24-2003, 03:06 PM   #15
Correct. The external harmonic ballancer was some stupid genius' idea in the 99+ models.
Old 07-24-2003, 09:01 PM   #16
proving once again the technologcal inferiority of the 99+. Well, except for that 40 hp gain, BUT PAY NO ATTENTION TO THAT, THEY ARE ONMLY TRYING TO SWOON YOU!
Old 07-25-2003, 05:15 PM   #17
well you need a puller to get the old one off and when you put it back on make SURE you tq it down to 125 lbs, i didnt and my check engine light came on, tq it down good and check it 3 or so days after to make sure the tq is still there on the bolt. run some lube around the place where the balancer slides over, and also run some thread lock on the bolts holdnig the pulley on (99 up only) pre 99 you only pop off the pulley and put another one on, very easy.
Old 07-25-2003, 05:16 PM   #18
also 01 up have naturally balanced set up with out a etch out of the balancer, make sure if you have 99 up you get the correct type for your car or you will really be messed up
Old 07-28-2003, 09:23 AM   #19
Could you explain a little more what you mean by "without a etch out"?
2003 Silver Metallic Premium Coupe, Auto
Mods: cai, raised gas pedal, window tint, lowered wipers :)
Waiting Install: intake spacer, Mach I Tokico shocks/struts, Ford C springs
On Order: udp
Planned: rear sway bar, dual GT take-off exhaust, Mach I chin spoiler
Maybe: 1.8rr, subframe connectors, panhard bar, aluminum drive shaft, 17" wheels, 3.73 gears/tlok or 8.8" swap, f2 fordchip or dynotune - or just wait and trade this 'stang in for a 2006 model
Hankster is offline   Reply With Quote
Old 07-29-2003, 07:56 PM   #20
the 01 up have a harmonic balancer that is totaly round with out any indention on the side of it, the pre 01 have a little groove on the side for balancing the engine, so you have to go crawl up under there and take a look to make sure you get the correct balancer.
pulley install - tough? 968 1996-2004 Mustang GT 9 08-14-2009 09:03 PM
nitrous sticky is gone!!!!! Monkey ME Site Help & Announcements 7 03-28-2004 04:47 PM
99-00 ASP pulley install JoeR. Pre-2005 V6 Mustang 5 12-11-2003 07:41 PM
help with pulley install quick! MusclesFromBrussels Pre-2005 V6 Mustang 3 08-19-2003 05:58 PM
***Underdrive Pulley Tech and FAQ*** Please Read 03zinc6 Pre-2005 V6 Mustang 27 07-31-2003 10:09 AM
07:46 AM
